Mac mini for hosting music files? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 41 Old 04-24-2013, 07:13 AM
BigEinBigD's Avatar
What is a zp90
BigEinBigD is offline
post #32 of 41 Old 09-11-2013, 11:00 PM
Scotty100's Avatar
I hope no one minds that I'm resurrecting this thread, which has been very useful to read as I learn about going digital in my system set-up. I also have just bought an apple tv and am in the process of reripping cd tracks in itunes to ALAC to improve sound quality. The question I have is on using a mac mini and how it actually is controlled to play music through my AVR. Can I hook the mac mini direct into my AVR via hdmi? And if so, then what - how would I control playing ALAC files stored in itunes on a mac mini that is acting as a media server? Finally, is it better, from a sound quality perspective, to stream wirelessly from a mac mini via apple tv or better to plug direct into the AVR? Thanks for any help with this...I realize they are newbie questions and hope they are not too dumb etc.
Scotty100 is offline
post #33 of 41 Old 09-11-2013, 11:39 PM
Tong Chia's Avatar
Originally Posted by BigEinBigD View Post
What is a zp90
One of these things
http://www.sonos.com/shop/products/connect
Digital music streamer that can read files off a server and play them over analog or spdif.
Tong Chia is offline
post #34 of 41 Old 09-11-2013, 11:46 PM
Tong Chia's Avatar
Yes, I have a 2011 Mini connected via HDMI to the AVR for multichannel sound.
Wireless streaming is prone to dropouts if your environment has a lot of RF (Radio Frequency) noise
I use iTunes as the interface and Audirvana as the actual player, it integrates into iTunes for the album and artist browsing.
http://audirvana.com/
Remote control via the Apple iTunes remote control on the iPad
https://www.apple.com/apps/remote/
If are using an Android tablet or phone then there is a similar app
https://play.google.com/store/apps/details?id=hyperfine.hftunes.release&hl=en
post #35 of 41 Old 09-17-2013, 09:53 AM
Scotty100's Avatar
Thanks for the reply. One more question - do you think using airplay to stream to the apple tv affects the sound quality of the music file? Do you get better SQ by having the mini connected directly into the receiver rather than going wireless? I have noticed a drop-off in SQ with alac music files since I started using an apple tv.
post #36 of 41 Old 09-17-2013, 01:20 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
No. I use an Airport Express rather than an Apple TV, and there are slight differences in how they work, but nothing that should be audible. At no point does the signal lose resolution.
What kind of a connection were you using before you got the Apple TV?
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #37 of 41 Old 09-17-2013, 06:44 PM
Scotty100's Avatar
Before I bought the apple tv I was just listening to my cds. Then I ripped them to ALAC and streamed via apple tv, optical out into my AVR, out to my B&W CM1s. First time I've really experimented with digital music in this way and I am a little disappointed. It's not terrible by any means and I love the convenience but I think I hear a difference in SQ from cd to ALAC streamed via airplay and even more so with music purchased from the itunes store (which I realize are 256kpbs but still it shouldn't be that noticeable, right?). Hence I was wondering if I could improve the sound by getting a mac mini and plugging directly into the AVR. Or indeed purchasing a network streamer and going that route into the AVR? Thanks for any advice!
post #38 of 41 Old 09-17-2013, 08:15 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
One possibility is that the feed from your old CD player is just a little bit higher in level than what you get when you feed a digital signal to your AVR, and that's what makes your CDs sound better. There's also the simple power of suggestion. People don't like to be told that "it's all in your head," but it often is, and we're all subject to it. (Your brain just can't forget that it's 256 kbps, even if you "know" that shouldn't make much difference.) I don't think a change in hardware is going to make a real difference in your case.
mcnarus is offline
post #39 of 41 Old 09-17-2013, 08:46 PM
Scotty100's Avatar
Yeah, I don't want to overthink decrease in SQ because I "know" it's 256kbps rather than lossless etc. However, I can't get away from what is quite noticeable sibilance when I play streamed ALAC files vs. their cd equivalents. Kinda driving me nuts...! Hence, I was wondering if equipment or source was to blame. No sibilance effect when playing cds...
post #40 of 41 Old 09-17-2013, 08:52 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Burn a CD-R from some ALAC files, and see how that compares to the original CD and the streamed files.
mcnarus is offline
post #41 of 41 Old 09-17-2013, 10:19 PM
Scotty100's Avatar
Good idea, I will do that. thanks
Reply CD Players & Dedicated Music Transports
