DAC and amp suggestions. - AVS Forum | Home Theater Discussions And Reviews
Old 02-13-2013, 06:30 PM - Thread Starter
DJ Kraemer's Avatar
First off, I'm sorry if I posted this in the wrong area.
I'm in the market for a nice, entry-level, two-channel system of separates. There's an overwhelming amount of gear out there, and simply put, I'm lost. A few suggestions would be great!
The source of my media will come directly from my PC, and thus I'd like some help choosing a great "bang for the buck" DAC and amp. My budget for both devices is $3,000 dollars, but I'd love to keep it at or under $2,000 if possible.
These will need to power and function the B&W 685's that I auditioned and fell IN LOVE with today. I couldn't believe how well these beauties sounded for the money.
As of now, I'm thinking about going with the Peachtree Audio NovaPre and 220 amp.
DJ Kraemer is offline
Old 02-13-2013, 06:58 PM
Tedd's Avatar
Quoted: 986 Post(s)
Liked: 365
NAD C390DD
Tedd is offline
Old 02-14-2013, 03:55 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1240
Piece of advice you probably don't want to hear #1:
Speaker auditions are generally a waste of time because the room so strongly affects sound quality. If you don't audition the speakers in your room, you don't know much about how they sound.
Piece of advice you probably don't want to hear #2:
Your enjoyment of the sound quality of your new system will heavily depend on your choice of a component you probably aren't even thinking of buying: The subwoofer. Up to half your speaker budget or 1/3 of your system budget should be spent there. The other component you probably weren't even thinking of buying are the acoustic treatments for your room.
Piece of advice you probably don't want to hear #3:
If you are actually interested in sound quality and not clinging to obsolete traditions, you will scrap all that and invest in a good AVR. They do 2-channel brilliantly and have features that you can't duplicate in separates without like doubling your budget.
Yes, you are in the wrong subforum. This question belongs in the Amp and Receiver area.
arnyk is offline
