Yamaha CD-N500 Networked CD Player Owners Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 107 Old 12-27-2014, 10:44 AM
sutton8's Avatar
Quoted: 179 Post(s)
Liked: 57
There is a newer version out now, the CDN301. AirPlay and spottily built in and a cheaper price point. Anyone got it?
7.2 Denon (X7200WA), Monitor Audio, Seismic 110, Oppo, XBOX, CCU, LG OLED (E6V)
5.1 Yamaha (RX-A1050), Focal Dome, LG OLED (EG920V)
Multiroom "Virgin V6, Zappiti, Harmony Elite"
sutton8 is offline
post #92 of 107 Old 12-27-2014, 12:51 PM
SkyWaLKeR1982's Avatar
Would be nice to have a firmware update with the airplay for the cdn500...specially now that there is a cheaper version with it...
SkyWaLKeR1982 is offline
post #93 of 107 Old 12-28-2014, 12:45 AM
sutton8's Avatar
Quoted: 179 Post(s)
Liked: 57
Doubt it. If you check the features tab on the products page they promised music streaming services by future firmware update. Other units in their range, such as the RN500, got Spotify but this one didn't.
http://uk.yamaha.com/en/products/aud..._w/?mode=model
sutton8 is offline
post #94 of 107 Old 12-29-2014, 06:24 PM
enlisted23's Avatar
Thanks for including the link. I'd really like to see both Pandora and AirPlay added to the CD-N500 if they could. And a FFWD function. Why do they list Vtuner as a feature on the 301 but not the 500? I use Pandora on a Sony BluRay player in another room but don't have it on my stereo so it would be nice if they could add it. I liked the AirPlay feature on the R-N500 but the amp itself was low quality.
enlisted23 is offline
post #95 of 107 Old 11-27-2015, 06:48 AM
Dubwiser's Avatar
Liked: 0
Hello!
I need to reactivate this tread with problem I have with my CD N500.
I had it more than 3 years as main source for digital and lossless. Very happy with sound at the first, connectivity option and grate look but in last few weeks I ve' noticed very loud pop from speakers between tracks using USB slot for my external HDD. Firstly it comes only when playing ripped flac files ( where tracks are separately recorded) also with some wav rarely with mp3 files.
This pops are connected with volume pot possition on my Nait 5i. Increasing volume on amp. following pop loudness from both speakers.
"Pure direct" option is constantly activated, I ve tried to turn on/off but without changes, pop still running ...
If I am using CD as source or internet radio, there is no any pop, only when I am switching sources what is quite normal for.
I have tried to change interconntect cable between amp and player, USB cable between HDD and Yamaha, power cable, speaker cables but nothings changed. Gapless option is turned on.
If some of owners has a similar problem or any idea how to fix I'll be very gratefull. If not, I should contact my local audio service in nearest future.
Thanks in advance!
Dubwiser
Dubwiser is offline
post #96 of 107 Old 11-27-2015, 02:41 PM
Try to reinstall the firmware using a USB disk and after that do a factory reset... Till now all problems I had with the unit had been solved this way
http://europe.yamaha.com/en/products...pc&tab=support
post #97 of 107 Old 11-28-2015, 01:40 PM
Dubwiser's Avatar
Liked: 0
Thank you for the first.
I made it, 2.07 version is currently available and through network not by disc. I've checked all the details for factory reset in avanced option so all suggested but nothings changed.
Very strange for me and few guys who knows something about audio. Some of them susspect on bad connection inside. I am still looking to avoid opening...
Dubwiser is offline
post #98 of 107 Old 12-04-2015, 04:50 AM
Dubwiser's Avatar
Liked: 0
There is no any other ideas about my topic?
Many thanks in advance.
Dubwiser is offline
post #99 of 107 Old 12-04-2015, 09:44 AM
Have you tried different hdd or using usb stick instead? Is your hdd a 3.5 or 2.5inch?
post #100 of 107 Old 12-05-2015, 01:43 AM
Dubwiser's Avatar
Liked: 0
It's same with other storages, nevermind it"s USB sticks or HDDs with the different power supply technology. Before posting here I suspect on my HDD with internal power supply through USB port. I was tried HDD with external power supply but I still hear loud pops when source is changing and between tracks when lossless files are choosen (flac, wav) and rarely with 320kbps mp3 files.
Dubwiser is offline
post #101 of 107 Old 12-06-2015, 08:18 AM
I can't think about any other solution to your problem... You may need to take it to a yamaha authorized repair center..
post #102 of 107 Old 12-07-2015, 02:30 PM
enlisted23's Avatar
I recall that the first firmware update started causing a pop when the pure direct mode was turned on or off on my player. Is it possible that the gapless mode is causing the pure direct to re-engage on lossless files? I don't use the gapless playback but do use WAV from a USB or FLAC from a NAS.
Is it possible that the disk or thumb drive is full or close to the folder/file limit? That shouldn't change with the MP3 files tho. The player does store a file in each folder for some reason.
Your amp is an analog integrated with RCA patch cords, right? Could you put an o-scope on the analog output to see what kind of waveform is causing the pop? Although there might not be anything that can be done to fix it. If it is a capacitive discharge, the extra load might have an effect too. The fact that it comes through both speakers could mean it's on the ground/shield part of the cable. It might be worth isolating the amp and CD-N so nothing but the speakers and power cables are connected to them.
post #103 of 107 Old 12-17-2015, 05:32 AM
Dubwiser's Avatar
Liked: 0
Hi enlisted23, thank you for all suggestions.
After reading your post, I've made a new firmware update but not helps. I was turned off gapless playback, with and without pure direct option activated but still nothings.
HDD capacity is not a problem, I have enough free space, around 40% so I don't see any reason to blame HDD for pops. To be sure, I will try to make partitions to separate folders.
Unfortunately I don't have o-scope to test Naim and Yamaha rca ports but I think they are ok. There is no any pops using CD unit so this test will be the last before sending to official service for test and possible repair.
As you mentioned now I am thinking that player makes separation between files inside folder by himself. It could be key point. On the other hand, I can hear pops when source is changing on Yamaha so I am not so sure is that a reason. If yes, I suppose that will be hard to fix in official service as well.
Your idea about components isolation from the rest of system looks fine. In upcoming days I will try to separate it with needed wires only ( power, speakers and interconnect cables). I'll be back with updated news what's going with pops after separation... Meanwile I will try to use Yamaha as transport only adding standalone DAC Musical Fidelity M1 via optical output just to improve Yamaha's DAC chip functionality.
Cheers!
Dubwiser is offline
post #104 of 107 Old 12-17-2015, 07:30 AM
Be aware that using an external DAC is going to make you lose gapless playback
post #105 of 107 Old 02-05-2016, 01:35 PM
Dubwiser's Avatar
Liked: 0
In last few weeks I 've tried in my system a few dacs from low and mid quality range. Decision was easy and out of a question. For 550eur 17 months old Hegel HD11 decision comes very easy. I can say that sound is now "dramatically" better than before with Yamaha as main source. Yamaha took place in system as a transport via coax. FTA digital cable to new dac. And no any pops now. Only sound ... no sound. SOUND :blush:
Cheers!
Dubwiser is offline
post #106 of 107 Old 02-06-2016, 10:19 PM
enlisted23's Avatar
external DAC
Cheers!
I'm planning on trying a new low cost SPDIF DAC from hifimediy.com that uses the ES9018k2m. They're taking preorders for $55 now for delivery in March. I wanted to try a sabre DAC for comparison with the wolfson.
post #107 of 107 Old 02-16-2016, 10:45 PM
enlisted23's Avatar
SPDIF volume control supported?
While I'm waiting for this part, does anyone know if the CD-N500 supports SPDIF volume control when used with an external DAC? The only way I can check this would be to move the unit to my AVR and connect the optical cable so I thought I'd ask here first.
Reply CD Players & Dedicated Music Transports
