Marantz CD6004 HDCD decoding? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-11-2013, 01:56 PM - Thread Starter
marko7's Avatar
Quoted: 14 Post(s)
I have a Marantz CD6004. I would like to know whether it can decode HDCD discs (properly). Does anyone know?
marko7 is offline
post #2 of 13 Old 03-11-2013, 04:06 PM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
The marantz website says nothing about it so, I'm guessing no, it probably just reads HDCD as a 44.1/16 bit recording.
glangford is offline
post #3 of 13 Old 03-13-2013, 11:16 PM
JA Fant's Avatar
Quoted: 232 Post(s)
Liked: 321
Either in the owner's manual or on the cd player itself, there will be the HDCD logo.
JA Fant is offline
post #4 of 13 Old 03-15-2013, 11:36 AM
Selden Ball's Avatar
Quoted: 3052 Post(s)
Liked: 1494
When a player can't decode HDCD, it needs to be decoded in the receiver or pre/pro that it's connected to. Unfortunately, however, HDCD support seems to be unavailable in most current generation audio equipment. A few universal players, like those from Oppo, and some dedicated CD players can still decode it, but I don't know of any almost-reasonably-priced current model receiver or pre/pro that does, not even the top-of-the-line Marantz AV8801. frown.gif
Selden
Selden Ball is online now
post #5 of 13 Old 03-19-2013, 11:35 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It seems like one approach would be to decode the HDCD on a PC using a decoder program such as:
http://www.foobar2000.org/components/view/foo_hdcd
or
http://www.roomyshare.com/File/bfk808lao09pg#
and then burn a regular CD from it.
arnyk is offline
post #6 of 13 Old 03-19-2013, 03:37 PM
SoNic67's Avatar
Liked: 29
That will do nothing good, since the 20 bit HDCD extension, burned on a CD will be truncated to 16 bit.
Now, true, some of the current HDCD recordings (like Lady Antebellum - Own The Night) don't use the range extension of HDCD, they record the CD trough HDCD mixer board just for the filters quality. But that is just a particular case, not the norm.
PS: Denon older top-line CD/DVD players and AVR's have also HDCD deconding.
SoNic67 is offline
post #7 of 13 Old 03-19-2013, 05:41 PM
JA Fant's Avatar
Quoted: 232 Post(s)
Liked: 321
IME, both older NAD & ROTEL gear had the most success w/ HDCD.
JA Fant is offline
post #8 of 13 Old 03-20-2013, 07:37 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
You've missed the point. Dithering HDCD recordings down to 16 bits can be easily predicted to do no sonic harm to them.
Ever heard of a level-matched DBT showing that HDCD actually made an audible difference with real world music?
Neither did I.
arnyk is offline
post #9 of 13 Old 03-20-2013, 09:47 AM
glangford's Avatar
Quoted: 197 Post(s)
Liked: 170
But then why would he need to decode it and burn a regular cd? A regular cd player will still play the hdcd without decoding the extra 4 bits. The process you suggest is not necessary.
post #10 of 13 Old 03-20-2013, 10:51 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The HDCD is not decoded exactly right when you play it on a regular CD player. What I'm suggesting is decode it exactly right, and then remove the low order bits in a way that preserves low level detail, which a Red Book player by definition can't do.
arnyk is offline
post #11 of 13 Old 03-28-2013, 04:40 PM
SoNic67's Avatar
Liked: 29
The only way to decode it 'right' is to play on a HDCD enabled CD/DVD/AVR player. Like Denon DCM-380, DVD-2910, 2930, 3930, AVR-3805 from my collection (just an example)...
Sure, the best way is to use a player with the 'official' PCM100 filter, but those tend to be expensive today.
Foobar2000 can decode it from any wav or flac file but it is not known how accurate it is since kode54 didn't disclose how he got the algorithm. WMP can decode it from CD's only (and since MS owns the HDCD logo now so it might be correct). But running those via crappy internal on-board sound card is an exercise in futility.
SoNic67 is offline
post #12 of 13 Old 03-29-2013, 06:58 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The fallacy here is the idea that something has to be flawed if we don't know exactly how it works.
Now if you had a technical test or a reliable listening test to back up your claim...
arnyk is offline
post #13 of 13 Old 03-29-2013, 02:00 PM
SoNic67's Avatar
Liked: 29
No, you have to prove that the unknown/reverse engineered source of that app is working as described by HDCD specs.
I don't need to prove the negative of something that you said in the first place.
SoNic67 is offline
Reply CD Players & Dedicated Music Transports
