Speakers for AT-LP60 Turntable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-25-2013, 02:03 PM - Thread Starter
bluesilo's Avatar
Hi,
I have a AT-LP60 Turntable and the TC-750LC Preamp and I'm looking for some bookshelf speakers to go along with them. I'm not looking to spend a ton right now (100$ probably), just want to hear my record player.
Any suggestions?
bluesilo is offline
post #2 of 6 Old 04-25-2013, 09:05 PM
Class A's Avatar
Quoted: 415 Post(s)
Liked: 1473
The Pioneer bookshelf speakers should fit the bill. You can get them at BB for around your budget.smile.gif
Class A is offline
post #3 of 6 Old 04-26-2013, 08:22 AM - Thread Starter
bluesilo's Avatar
Do you mean these?
http://www.bestbuy.com/site/Pioneer+-+4%26%2334%3B+Bookshelf+Speakers+(Pair)/5086955.p?id=1218610014045&skuId=5086955&st=Pioneer%20bookshelf&cp=1&lp=1
Also when working with speakers like this...do I need banana plugs in order to plug them into the other devices?
bluesilo is offline
post #4 of 6 Old 04-26-2013, 08:48 AM
Class A's Avatar
Quoted: 415 Post(s)
Liked: 1473
Yes. That depends on what your receiver takes. Not pretty but they do sing.smile.gif
Class A is offline
post #5 of 6 Old 04-27-2013, 02:50 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
Aren't those Pioneer speakers passive? The OP doesn't appear to have an amp, just a phono stage (which he doesn't need, actually).
To the OP: First, return the phono preamp, if you can. You already have one built into your turntable. That will up your budget a little. What you need are a stereo receiver as well as a pair of speakers. I doubt you can do that for less than $200-300, unless you buy used.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #6 of 6 Old 04-27-2013, 04:00 PM
Class A's Avatar
Quoted: 415 Post(s)
Liked: 1473
He said other devices so I assumed he meant a receiver. But you may be correct. confused.gif
Class A is offline
Reply CD Players & Dedicated Music Transports
