Dual voltage audiophile turntable recommendations. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-05-2013, 07:45 AM - Thread Starter
foobar007's Avatar
I'm looking for dual voltage (110v and 220v), audiophile turntable. Looking for something in < 700$ range.
Any recommendations?
TIA.
foobar007 is offline
post #2 of 4 Old 07-05-2013, 04:19 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
The power usage of turntables is so tiny that a 120/240 power transformer of minimum size would be very effective.
arnyk is offline
post #3 of 4 Old 07-15-2013, 06:32 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Do not forget frequency difference. You need either direct drive table with quartz locked motor or speed controller for synchronous motor. In the latter case you will likely exceed your budget, as this is considered a high-end featre.
ap1 is offline
post #4 of 4 Old 07-15-2013, 02:54 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Good point. There are a number of ways to make a turntable not care what the power line frequency is, or have dual speeds, some electrical, some mechanical.
USA = 60 Hz, much of the rest of the world = 50 Hz. The 60 Hz in the USA is pretty stable, but the power line frequency in much of the world, not so much.
arnyk is offline
Reply CD Players & Dedicated Music Transports
