Low hum from properly grounded turntable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-18-2013, 08:44 AM - Thread Starter
billg66's Avatar
Last night I hooked up my new AT LP-1240 to my Onkyo TX-SR601 receiver. I grounded the turntable to a case screw on the Onkyo, so there is no 60 cycle buzz (I disconnected the ground from the Onkyo with the turntable powered up, and, believe, me, I heard the buzz, which immediately went away when I reconnected the ground).
The thing is, there's a low level hum that's present, even when the power to the turntable is turned off. It's a tad louder when the power is on, but still present even when the power is off. I can also hear the hum waver a bit between album tracks... like it surges a bit then recedes. The turntable is isolated from any other audio components (the receiver is at the opposite end of the entertainment center)... so, I'm just wondering if anyone has any suggestions of what I might try to eliminate that hum. A power conditioner?
--Bill
billg66 is offline
post #2 of 4 Old 09-18-2013, 08:16 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Got a laptop that you can carry over and check how much hum its USB output has?
arnyk is offline
post #3 of 4 Old 09-19-2013, 08:08 AM - Thread Starter
billg66's Avatar
Yes, I do... I'll give that a try as soon as I can. What might the presence/absence of hum prove?
billg66 is offline
post #4 of 4 Old 09-19-2013, 11:28 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If the hum is less with the USB connection then it might suggest that there's something going wrong with your connection to the preamp.
arnyk is offline
Reply CD Players & Dedicated Music Transports
