Sony PS-X6 Problems! Please help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-23-2013, 11:39 AM - Thread Starter
iKokomo's Avatar
     We have a Sony PS-X6 that sat unused for about 10 years and the we got into vinyl again and started to use it again a month ago. 10 years ago it was working perfectly, when we brought it out to test it again, there was a sound inside that sounds like gears grinding and the record player does not play at a constant speed on 33rpm. (sometimes it does, but most of the time it does not)
     When playing 45s though it normally plays at the correct speed. (yet sometimes it does not).
     When opened up this video is what we saw. http://www.youtube.com/watch?v=wUT7W25i-2Q
     Please help, would love to get this thing back in working order! Thanks a lot!
iKokomo is offline
post #2 of 4 Old 10-23-2013, 09:24 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 80
Good video there of the problems. My first thought was that the oil/grease has gummed up in one or more of the gears -- but that's really little more than a guess. You'd get more feedback on this over at www.vinylengine.com.
skriefal is offline
post #3 of 4 Old 10-24-2013, 04:47 PM - Thread Starter
iKokomo's Avatar
Thanks for your help! It looks like I will research, then rip it apart grease it up and put it back together! :)
iKokomo is offline
post #4 of 4 Old 10-24-2013, 05:02 PM
skriefal's Avatar
Quoted: 97 Post(s)
Liked: 80
I saw your post over at Vinyl Engine after I posted the above. Looks like you got pretty much the same suggestion over there, albeit much more verbose than my brief response. smile.gif
skriefal is offline
Reply CD Players & Dedicated Music Transports
