No USB input on Bose Player - AVS Forum | Home Theater Discussions And Reviews
Old 11-17-2013, 08:39 AM - Thread Starter
Tristateviewer's Avatar
I have a Bose radio player with phono inputs to connect a cd player with phono outputs but it has no USB input. I have a USB flash drive stick with music on it that I would like to play on my Bose player. Is it possible and if it is, how can I do this? Does this require a USB type of player to be connected and what kind of adapters would I need?
Tristateviewer is offline
Old 11-17-2013, 09:30 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
I'm just guessing but I think you might have to copy the data out to CDR.
FMW is offline
Old 11-17-2013, 12:36 PM - Thread Starter
What is a CDR?
Old 11-17-2013, 12:39 PM
swim33's Avatar
It means burning it to a disc.
-Ben
swim33 is offline
Old 11-17-2013, 01:22 PM
FMW
FMW's Avatar
Liked: 1681
What is a CDR?
CD-R (recordable CD) would have been more accurate. It is a CD to which you can record. Your computer is likely capable of handling it. It is a common thing to do.
FMW is offline
Old 11-17-2013, 02:45 PM
SoNic67's Avatar
Liked: 29
You need a flash mp3 player (with those songs transferred into), connected to the line-in of the Bose. Since that Bose is not a high audio quality radio anyway, you will not loose anything.
For example: http://www.amazon.com/Silver-Metal-Clip-Player-supports/dp/B004S42RSW/
SoNic67 is offline
