Olive 6HD problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-26-2013, 09:17 AM - Thread Starter
stebro's Avatar
Quoted: 66 Post(s)
Liked: 27
My Olive 6HD has a problem. When I turn it on, it stops at the white "Olive" screen. A couple of times, it goes past that screen and then displays a message saying "404-not found". I contacted Olive and they advised me to do the USB stick recovery. Fortunately, I do have things backed up. I followed all the USB recoveryl tnstructions but, when I get the message on my Olive saying "insert USB stick" and do so, nothing happens. I've tried re-inserting in several times and leaving it in for an hour or more but it's not working. I would appreciate any suggestions.
stebro is offline
post #2 of 3 Old 01-23-2014, 11:49 PM
Dreamstimer's Avatar
I have exactly the same problem, how did you solve it?
Dreamstimer is offline
post #3 of 3 Old 01-27-2014, 02:22 PM
clpetersen's Avatar
Quoted: 193 Post(s)
Liked: 59
Some time ago I installed a new hard drive in out 06HD (went to a near-silent notebook drive). Did the restore routine to put the Olive OS on the new drive - no issues.
However, and this is important, the restore files were large (~2 GB if I recall). I had to do several downloads before I got two copies that matched exactly. I used this copy.
Reinstalling the music from the back-up also worked without issues.
clpetersen is offline
Reply CD Players & Dedicated Music Transports
