CD player placement—OK to stack? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-04-2013, 05:10 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Got a new Onkyo 7030 (which I am loving so far) and I'm wondering if it's OK to have the cable box on top of it, like in the pic below? As you can see, there's really no other place to put the darn thing. The Onkyo's case is solid on top, so there aren't any vents to block. The cable box does have vents on the bottom, so some heat is exiting there. I'd think most of it would be leaving the top of the cable box since heat rises. Do you think this is OK for the CD player?? Yeah, I'm a little anal rolleyes.gif
milehighou is offline
post #2 of 11 Old 12-05-2013, 10:51 AM
Assoc. Editor @ AVS Forum
imagic's Avatar
Quoted: 4950 Post(s)
Liked: 8373
You will not have any issue because CD players do not have vents on top of the chassis, as as you said... heat rises.
Mark Henninger
imagic is online now
post #3 of 11 Old 12-05-2013, 11:08 AM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
Awesome, thanks.
post #4 of 11 Old 12-05-2013, 12:56 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
Is there a few inches of space above the cable box for air to flow freely? If not then you may have reliability issues with the cable box. Those usually have air entering from the bottom and leaving through the top.
skriefal is offline
post #5 of 11 Old 12-05-2013, 01:19 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
It's pretty close to that glass shelf...maybe like half an inch or less. Not ideal, but there is an air gap there. I'll keep an eye on it and see how hot it gets.
post #6 of 11 Old 12-05-2013, 04:34 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
+1. Does the cable box have feet that make it stand a half inch or so above the 7030, or is it one of those that sits almost flat (with no feet)? If the cable box sits flat against the 7030, I bet the top of the 7030 will get quite warm to the touch. Try it. If it feels pretty hot, put some standoffs/feet between the two.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #7 of 11 Old 12-05-2013, 05:15 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
There's tiny legs on the box, so it's not in direct contact with the top of the player. It's maybe 1/4 inch gap. It seems OK so far. I can feel a little warmth, but it's not blazing hot or anything.
post #8 of 11 Old 12-05-2013, 05:42 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
If it's not getting really hot to the touch, then you're probably fine as is. If it gets really hot to the touch, then use some sort of standoffs to get a good 1/2 inch or more of space between the two.
beaveav is offline
post #9 of 11 Old 12-05-2013, 06:05 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
If the cable box manufacturer used 1/4-inch legs then that's almost certainly because their testing found that 1/4-inch was sufficient space to pull in air below the unit. If there is a problem here, it'll be the limited open space above the box. Usually you want at least a few inches of free space above any electronic component that generates much heat. If this cable box does generate much heat -- which is likely if it's a DVR -- then it'll cook.
skriefal is offline
post #10 of 11 Old 12-05-2013, 08:02 PM - Thread Starter
milehighou's Avatar
Quoted: 876 Post(s)
Liked: 208
To be honest, I'm more worried about my CD player. If something happens to the cable box, I can always play dumb and get another one wink.gif I might feel a little guilty, but not too much. The cable company has been ripping me off for years.
post #11 of 11 Old 12-06-2013, 03:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
No doubt, But if anybody has any concerns, get a non-contact thermometer and measure the temperature of the chassis of your equipment. It should be below 110 degrees F.
http://www.amazon.com/Nubee%C2%AE-Temperature-Non-contact-Infrared-Thermometer/dp/B00CVHIJDK
Welll under $20 delivered.
arnyk is offline
Reply CD Players & Dedicated Music Transports
Onkyo C 7030 Compact Disc Player Black
