Marantz cd6000 Ki signature vs cd 6005 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 12-20-2013, 09:56 AM - Thread Starter
alfar's Avatar
Hi I'm new on here and although it's an awesome resource I'm finding some of the posts a bit intimidating to say the least! I mean that in the way I don't know much about the electronics and technical stuff!
My humble questions are;
I have a Marantz cd 6000 Ki sig and I LOVE the sound from it, it's now almost 10 years later starting to skip and not read discs. Should I have the laser assembly replaced and will it affect the sound/performance?
Should I just move onto the new cd6005 with its rave reviews and how does it compare sound wise?
Thank you in advance! Alan 😊👍
alfar is offline
post #2 of 17 Old 12-25-2013, 09:31 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Actually, you can get the CD5004 for only $349.
It is amazingly good.
I am certain that it will sound much better than your old one. The DAC chips in it are SO much more accurate and capable than the 15-year-old chips in the 6000 that there is little comparison.
Stereophile tested it recently and was very impressed with it. I suggest that you check out that review online.
I wouldn't waste a lot of money on an old unit whose reliability will always be questionable, and whose DAC chips are 3 generations beyond obsolete. Time marches on.
commsysman is offline
post #3 of 17 Old 12-25-2013, 10:16 AM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
DACs I tested in the late 90s had excellent performance. The biggest differences I saw between DACs then and now are 1) price went way down for similar performance 2) DAC chips got smaller and used less power 3) audio DACs are now often included in chips that do other things, such as audio processing, video processing, etc. Time marches on, indeed.
As far as audibility goes, the new ones will sound excellent, just like the old ones did. smile.gif
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #4 of 17 Old 12-25-2013, 10:47 AM
FMW
FMW's Avatar
Quoted: 1653 Post(s)
Liked: 1687
+1
FMW is offline
post #5 of 17 Old 12-27-2013, 01:01 AM - Thread Starter
alfar's Avatar
Hey thanks everyone for the feedback ok you've helped me make my mind up! I've managed to find the CD 5004 online for a bargain at just under €200!! I don't need USB ports etc on my player just a solid CD player so hopefully this one will do the job. Ill post my opinion when it arrives so thanks again guys really appreciate your input! 👍😊
alfar is offline
post #6 of 17 Old 01-02-2014, 06:05 AM - Thread Starter
alfar's Avatar
Well CD5004 just arrived today so have it set up. Hard to tell just yet if it sounds better than the 6000 Ki but I suppose it will take time to break in. On that note can I ask what's the duration/procedure for burning the laser in or do I even have to do that? Thanks a million again! Alan 😊
alfar is offline
post #7 of 17 Old 01-02-2014, 10:14 AM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Hard to tell if it sounds better because they both probably sound the same.
There is no break-in needed for the laser or for anything else on a CD player.
beaveav is offline
post #8 of 17 Old 01-02-2014, 11:36 AM - Thread Starter
alfar's Avatar
Hi Beaveav thanks for replying, glad to hear that. I've always thought it's just sensory adaptation that gives the CD players their different sound. Either way I'm loving the detail from this player, can't believe I picked this up for 200€ shipped. It does a great job of MP3 playback too! So far, very happy, thanks again Commsysman for the recommendation too! 👍😊😊😊👍
alfar is offline
post #9 of 17 Old 02-22-2014, 04:09 AM - Thread Starter
alfar's Avatar
Just an update on this post. Thinking of replacing my 12 yr old NAD C340 amp with the matching pm5004 amp for my Cd5004. I can get it for under 200€ Any opinions on whether that should make any difference? Should I stick with the NAD? I have Monitor Audio BX2s. Thanks guys!
alfar is offline
post #10 of 17 Old 02-24-2014, 10:54 AM
par4's Avatar
SOME of the new ones MAY sound excellent, just like SOME of the old ones did. Others, ehh, not so much.
par4 is offline
post #11 of 17 Old 02-24-2014, 03:58 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Uhm, I think you mean this:
NEARLY ALL of the new ones DO sound excellent, just like MOST of the old ones did. Rare exceptions, ehh, yeah, not so much.
beaveav is offline
post #12 of 17 Old 02-24-2014, 04:51 PM
tbase1's Avatar
Quoted: 47 Post(s)
Liked: 70
will be listing my Marantz cc63se in 8 rated condition.
tony4k
tbase1 is offline
post #13 of 17 Old 02-24-2014, 10:00 PM
par4's Avatar
My, my. That's a rather long nose you're looking down, Chiefy. And, like some of the other "lab" evaluators that contribute to this forum: you see, but you do not observe, Watson.
Live and learn.
par4 is offline
post #14 of 17 Old 02-25-2014, 03:45 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Live and learn.
Wait, you accuse me of looking down a long nose, then you follow it up with a condescending insult assuming I don't understand what I test or that I don't listen to what I test - when you know nothing about me or my background.
beaveav is offline
post #15 of 17 Old 02-25-2014, 05:39 PM
par4's Avatar
Well, somebody doesn't like the taste of their own medicine, eh? If the shoe fits, my friend.....
par4 is offline
post #16 of 17 Old 02-25-2014, 05:46 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 669
Got any more cliches or folksy sayings to share instead of, you know, actual content?
beaveav is offline
post #17 of 17 Old 02-25-2014, 09:14 PM
par4's Avatar
Sure. I'll send you a copy of my book. You'll love it.
par4 is offline
Reply CD Players & Dedicated Music Transports
