Will repeated plugging/unplugging wear out 3.5mm jack? - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2014, 09:53 AM - Thread Starter
CLEHD's Avatar
(I am not sure if this is correct forum for this topic and I apologize if it is not. Please direct to the correct one if need be)
I recently switched my SiriusXM subscription to online-only in order to get some channels which my older, in-car receiver cannot (24/7 Pink Floyd sounds darn good to me biggrin.gif). I downloaded the SiriusXM app onto my phone in order to listen in my car. I do not have Bluetooth connectivity in my car, but I do have an AUX In jack.
I was wondering/concerned about the possibility of wearing-out the 3.5mm jack on the phone from repeated plugging and unplugging of the 3.5mm cord. Is this something of real concern?
I looked into Bluetooth devices which plug into the AUX In jack which would eliminate the need for the 3.5mm cord, but each have their pro's and con's of course.
CLEHD is offline
Old 01-15-2014, 09:57 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
It is possible, for sure. 3.5 mm jacks are generally pretty fragile, but there is quite a range of durability on the market. The quality of the assembly of the jack and the cord also matters. IME right angle plugs tend to be more durable because they don't provide as long of a lever arm for bending forces.
arnyk is offline
Old 01-15-2014, 10:03 AM - Thread Starter
CLEHD's Avatar
I am not 100% sure what you mean by "bending forces", but if I interpret what you are saying correctly then I will say that there is no tension on the connection whatsoever. My phone (iPhone 5S) is perhaps 1.5 ft at most from the AUX In jack and the cord is 4 ft long I believe. Plenty of slack. If I interpreted your statement incorrectly, I apologize.
My concern revolves around the friction/rubbing/what have you of repeated plugging & unplugging.
CLEHD is offline
Old 01-15-2014, 12:12 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If the plug is gold plated, the gold being soft will eventually get scrubbed off from multiple insertions. If it was a quality job of gold plating, there will be a layer of nickel or similar harder protective metal under the gold that will maintain the corrosion free nature of the plug. Gold is eschewed by professionals in a high use application for this reason.
arnyk is offline
