Teac PD-D1200 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-23-2014, 09:19 AM - Thread Starter
rebs's Avatar
does anyone know if this cd player is anolog or digital ?
rebs is offline
post #2 of 5 Old 01-23-2014, 09:33 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
All CD players are digital. If you use a digital output it will stream the data to whatever you connect. If you use an analog output it wall send decoded analog waveforms to whatever you connect.
FMW is offline
post #3 of 5 Old 01-23-2014, 01:23 PM - Thread Starter
rebs's Avatar
My Teac has only one out put and when it is connected to my Yamaha RX-V375 the display shows analog. Why wouldn't it show digital ? Perhaps I have it plugged into the wrong in put on the Yamaha ?
rebs is offline
post #4 of 5 Old 01-23-2014, 02:08 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
If it plays, you're not sending it to the wrong input. The reason your receiver says analog is because the CD player has converted the digital to analog and is sending an analog signal to the receiver.
Some CD players also have a digital output. Using that, it would be the receiver that does the converting.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #5 of 5 Old 01-23-2014, 03:55 PM - Thread Starter
rebs's Avatar
Thank you for the information, I appreciate it
rebs is offline
Reply CD Players & Dedicated Music Transports
