Does CDP Analog and digital out work at the same time? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-04-2014, 10:38 AM - Thread Starter
phcpbl's Avatar
When I using a CD player ANALOG OUT (connected with an integrated amp) to play a CD, could I use the DIGITAL OUT (connect to a DAC) at the same time?
Thank you.
phcpbl is offline
post #2 of 4 Old 02-04-2014, 10:45 AM
sivadselim's Avatar
Quoted: 267 Post(s)
Liked: 224
I would say, most likely, yes. I can't speak for all players, but the 3 players that I have familiarity with will.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #3 of 4 Old 02-05-2014, 04:39 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Thank you.
If the digital out is coax or optical, almost absolutely surely both the analog and digital outputs work at the same time. As a rule those outputs don't inform the device as to whether there is anything attached to them or not.
HDMI can be a different story - the player "knows" what and if something is attached to it and may be making choices for you.
arnyk is offline
post #4 of 4 Old 02-05-2014, 10:14 AM - Thread Starter
phcpbl's Avatar
Thank you for the information.
phcpbl is offline
Reply CD Players & Dedicated Music Transports
