Adding CD player to AVR and dedicated headphone amp. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-11-2014, 03:08 PM - Thread Starter
Gloomba's Avatar
I used to listen to nothing but FLAC/320kcbr on my Onkyo TX-NR717 and Schiit Asgard 2, but I came across a bunch of old CD's and do not want to rip them. Since my Onkyo has a DAC does this mean I don't need to buy a 'good' CD player? One that doesn't have it's own DAC? I have Sennheiser HD600's as well so I am definitely not wanting my CD player to be the weak link in my headphone set-up. If I do end up buying a CD player with a DAC, how do I tell my system to use the one in my Onkyo, rather than the one inside the CD player? Thanks in advance for your time/help.
Gloomba is offline
post #2 of 3 Old 02-11-2014, 04:12 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Virtually all CD players have DACs. if you get one with a digital output you can use that to send the data to your AVR's DAC. My advice is to get a Blu Ray player instead. It will be less expensive, do the same job and even allow you to play videos if you like. If your AVR or preamp has a headphone output, that should work the same as a dedicated headphone amp. All of these devices have noise and other issues well below the level of audibility.
Gloomba likes this.
FMW is offline
post #3 of 3 Old 02-11-2014, 05:06 PM - Thread Starter
Gloomba's Avatar
Hah, I must be a bit daft -- never thought about using a blu-ray player. I have a ps3 and it's already going through my Onkyo *face palm*
Gloomba is offline
Reply CD Players & Dedicated Music Transports
