Can't find my downloaded music. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-13-2014, 03:51 PM - Thread Starter
warren kice's Avatar
I have successfully downloaded several albums from HD tracks and integrated them into the Maestro library following the Olice/Maestro protocol. However, the last download has created a mystery. After completing the download and the import to Maestro, I can't find the music ("Kind of Blue" by Miles Davis) in my Maestro library! I've searched all possibilities in my library (including "unknown artist") but simply can't find it.
Any suggestions?
warren kice is offline
post #2 of 6 Old 02-13-2014, 06:39 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Is there a reason you posted this again? Proper protocol is to "BUMP" the original thread to the top, not make a second post. wink.gif
jdcrox is offline
post #3 of 6 Old 02-14-2014, 04:51 AM
Moderator
Moderator
PooperScooper's Avatar
Quoted: 286 Post(s)
Liked: 3974
Actually, AVS does not want people to bump threads. All threads are equal and most of the time if somebody reads the thread and can help, they will respond.
From the AVS Terms of Service: ".... Also do not "bump" threads as it is not a kind thing to do. ...."
larry
And the pantaloon duck, white gooseneck quacked: Webcor, Webcor
PooperScooper is offline
post #4 of 6 Old 02-14-2014, 08:38 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Sorry Larry, when I was a moderator on other forums, it was always preferred that posts be "bumped" once a day, rather than start a new post and clutter up the page. I apologize for not fully understanding the TOS here.
jdcrox is offline
post #5 of 6 Old 02-14-2014, 11:24 AM
Roseval's Avatar
Quoted: 37 Post(s)
Liked: 25
Maybe a audio format not supported by Olive?
As you have them on the PC, can you see any tagging information?
Roseval is offline
post #6 of 6 Old 02-14-2014, 03:11 PM
clpetersen's Avatar
Quoted: 162 Post(s)
Liked: 52
I had a similar problem, with a 24 bit sampler/compilation album from a HD site. Everything got split off and impossible to find. So I edited the metadata (on the MAC/PC) and put all the tracks into an album of my naming. Problem solved.
Yes, try to check the embedded metadata.
clpetersen is offline
Reply CD Players & Dedicated Music Transports
