Turntable repeating - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-19-2014, 10:58 AM - Thread Starter
docwoody's Avatar
I've recently acquired a Harmon Kardon t55c turntable from my father. As I was transporting it I broke the cartridge that was on it a a Shure M111HE and have since upgraded it to a Shure m97x. However, I can't seem to get the turntable to function properly. I can listen to about 15 seconds of any song on many different records before it starts repeating over and over until i add slight pressure. As soon as I let off pressure it begins to repeat again. I have already inspected under the table for something loose and fiddled with the tone arm adjustments as well as placing a penny on the cartridge and still have not found a solution. This is my last shot at trying to fix it myself before I send it off to get repaired. Below is a picture of how the cartridge is sitting on the record. It seems to be slightly touching the record which cannot be right at all. Thanks in advance.
docwoody is offline
post #2 of 5 Old 02-19-2014, 01:28 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
It doesn't need to be repaired. The cartridge needs to be mounted properly. I suggest finding someone locally who can do it for you.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 5 Old 02-19-2014, 03:15 PM - Thread Starter
docwoody's Avatar
Unfortunately I don't have any shops near me. Any other suggestions?
docwoody is offline
post #4 of 5 Old 02-19-2014, 05:10 PM - Thread Starter
docwoody's Avatar
I've done a bit more of research and watched several Youtube videos. Turns out I had the weight set wrong by about 5 grams. Dialed it down to 1.25 grams. Works flawlessly.
docwoody is offline
post #5 of 5 Old 02-19-2014, 05:41 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 374
You know, it occurred to me that you might have set the tracking weight wrong, but then I said to myself, "Nah, he couldn't have done anything that inane. Give him some credit." smile.gif
Glad you found the fix. Welcome to VinylWorld.
mcnarus is offline
Reply CD Players & Dedicated Music Transports
