Maranz UD7007 for example - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-21-2014, 07:07 AM - Thread Starter
Dobson's Avatar
Hi
Is there any point in purchasing a Blu-ray/ CD player with a separate Pure Direct outlet and using it with my Pioneer SC-2022 receiver that has Pure Direct?
Here I'm talking about normal stereo CDs.
Do
Dobson is offline
post #2 of 6 Old 02-21-2014, 08:32 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
I have no idea what a pure direct output is on a Blu Ray player. The player should have some sort of analog and some sort of digital (such as HDMI) output. If you use the analog ones, the DAC in the player will be the one that is used. If you use the digital output, the DAC in the AVR will be the one that is used. It best practice to keep the data in digital form for as long as possible in the audio chain, so I recommend buying a Blu Ray with an HDMI output and connecting that to the AVR. Then you can use the AVR to process the signal or disable processing (pure direct) as you prefer.
FMW is offline
post #3 of 6 Old 02-21-2014, 02:53 PM
par4's Avatar
Originally Posted by Dobson View Post
Hi
Do
Probably two different things. If you use the analog outs on the Marantz, the Pure Direct will disable (turn off) everything else on the player except the signal moving through the DACS to the analog outs.
If you use the 7007 as a transport and send the data to the receiver, the receiver's DACs will convert it to analog, and the Pure Direct (if turned off) will pass it through to the analog outs without further processing.
par4 is offline
post #4 of 6 Old 02-22-2014, 03:37 AM - Thread Starter
Dobson's Avatar
At the moment, I am using a Sony BDP-S790 player connected to my Pioneer SC-2022 receiver and playing my normal CDs in Pure Direct mode.
Let's pretend for a moment I have the hearing of a healthy baby, would I be able to notice the difference using the Maranz with its Pure Direct HDMI output connection compared to the Sony?
Dobson is offline
post #5 of 6 Old 02-23-2014, 12:41 AM
par4's Avatar
The Marantz Pure Direct is for use with its analog outs.
par4 is offline
post #6 of 6 Old 02-23-2014, 01:36 AM
FMW
FMW's Avatar
Liked: 1684
Not in a bias controlled listening test.
FMW is offline
Reply CD Players & Dedicated Music Transports
Marantz Ud7007 Universal Disc Player With Networking Black
