newbie trying to get a entry level HiFi stereo - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-23-2014, 07:35 PM - Thread Starter
fanism's Avatar
Hi,
I am trying to get an entry level HiFi stereo for my study room.  After some browsing and thoughts, I am down to 2 choices.  May I ask, in your professional opinions, which is better and/or more worthy to purchase?  I need it solely to play CDs and maybe sometimes connecting to iProducts.
1. Yamaha MCR-223 (or MCR-323 with an upgrade of the finish)
http://usa.yamaha.com/products/audio-visual/hifi-systems/mcr-232/?mode=model
2. Denon D-M39S
http://usa.denon.com/us/product/pages/productdetail.aspx?pcatid=audiocomponents%28denonna%29&catid=shelfsystem%28denonna%29&pid=microcomponentsystem%28denonna%29
Thank you very much
fanism is offline
post #2 of 6 Old 02-24-2014, 04:10 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by fanism View Post
Hi,
2. Denon D-M39S
Thank you very much
Are you limited by space or money?
arnyk is offline
post #3 of 6 Old 02-24-2014, 09:48 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
They're pretty much equivalent. If you have the space and can spend a little more, you would be better off buying separate components than an all-in-one system. But if you have space/money constraints, those are reasonable choices. Id' say go with whichever is the best deal.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 6 Old 02-24-2014, 10:50 AM - Thread Starter
fanism's Avatar
Thank you for your response.
I am both space and budget tight.  I guess I will go with the one with a better deal. :)
fanism is offline
post #5 of 6 Old 12-25-2014, 09:38 AM
audiolan's Avatar
Liked: 1
http://www.amazon.com/Marantz-M-CR61.../dp/B00DS5Z0J0
How about this?
Hopefully I can get it or make it for cheaper!
audiolan is offline
post #6 of 6 Old 12-25-2014, 10:08 AM
MrBobb's Avatar
Quoted: 164 Post(s)
Liked: 63
Seriously? He's looking for transportation and you are suggesting a $sports car.
I prefer the more "classic" look of the Yamaha if that matters anything, but can't stack anything on top with those jacks. Would be nice to have built-in wireless, BT or Airplay but oh well.
MrBobb is offline
Reply CD Players & Dedicated Music Transports
