Looking For CD Changer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-26-2014, 05:59 PM - Thread Starter
CarvinAbuser's Avatar
Hello friends at the AVS Forum,
My Philips CDR820 recently broke and I'm looking for a new CD changer that will play mp3 CD's.  I tried new ones from Yamaha and a Sony, but the mix did not sound right.  The bass was weak and the vocals were up in the mix.  Any suggestions would be appreciated.
CarvinAbuser is offline
post #2 of 7 Old 02-26-2014, 09:50 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3109
What's your budget? I would suggest accessories4less.com. They often have the Denon and Marantz changers at very reasonable prices.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is online now
post #3 of 7 Old 02-27-2014, 05:23 AM - Thread Starter
Thanks for the response.  I don't want to spend much more than $400.
post #4 of 7 Old 02-27-2014, 05:32 AM - Thread Starter
The Onkyo DXC390 looks good, do you think it will give me the "classic" sound I'm looking for?
post #5 of 7 Old 02-27-2014, 09:17 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
I would spend that money on a streaming unit with a remote control. You can then rip your cd's to digital computer files and play them on your streamer. You can develop playlists that will do exactly the same thing as the changer but without all the delays of a changer. Seriously, not many of us use CD players any longer.
FMW is offline
post #6 of 7 Old 02-27-2014, 09:23 AM - Thread Starter
I might consider that in the future, but I don't have the time now. I still make mp3 discs and play them on different units, home and car.
post #7 of 7 Old 02-27-2014, 11:25 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3109
I haven't heard this particular player but any competent unit should have good SQ. If you're using an AVR/DAC you can just connect using coaxial or optical.
Reply CD Players & Dedicated Music Transports
