What do I look for in purchasing a turntable used or new? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-31-2014, 09:48 AM - Thread Starter
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
I was thinking about getting into vinyl and wanted to know what would do I consider for under $200 for one, used or new?
What are the important factors for upgrading/improving one if I got a used one?
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is online now
post #2 of 15 Old 03-31-2014, 10:30 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
This is just my opinion, but if you have to ask this question, you probably shouldn't be buying a used turntable. And you can't buy anything decent new for that price.
kabusa.com sells refurbed Technics SL20BD tables for $200 that have been thoroughly gone over and fixed up by a true turntable maven. In your price range, that's the only thing I can recommend.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 15 Old 04-08-2014, 09:16 AM
grennels's Avatar
If you can buy a Technics SL20BD refurbed for $200, grab it.  Strong, durable, decent sounding turn table.
Been running mine since about 1975.  Refurbed once.
grennels is offline
post #4 of 15 Old 04-08-2014, 10:25 AM
Theresa's Avatar
Liked: 51
One thing I recall is a low mass tonearm is best. Many of the Technic's do not have this.
Theresa is offline
post #5 of 15 Old 04-08-2014, 01:13 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
What you are recalling is an old audiophile myth. The truth is more complex than this. These days, truly low-mass tonearms are pretty rare outside the high-end stratosphere.
mcnarus is offline
post #6 of 15 Old 04-08-2014, 01:14 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Check the model number. I don't believe Technics was making that particular model 40 years ago. What you have may be similar, or it may be very different but with a similar name.
mcnarus is offline
post #7 of 15 Old 04-08-2014, 02:35 PM
grennels's Avatar
Yep. My bad. SL23. Please apply my previous remarks to this model.
grennels is offline
post #8 of 15 Old 04-08-2014, 02:39 PM
grennels's Avatar
grennels is offline
post #9 of 15 Old 04-09-2014, 07:39 PM - Thread Starter
post #10 of 15 Old 04-10-2014, 10:16 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
I can only speak for the quality of the SL20BD. The other one appears to have been part of a one-brand system, which tended not to be high quality.
If you buy a used table, you should almost certainly get a new cartridge right away (and maybe a new belt), so you have to figure that into the cost.
mcnarus is offline
post #11 of 15 Old 04-10-2014, 06:56 PM - Thread Starter
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
On the ebay link for the SL20BD it says: Requires an adapter for playing 45 rpm records Not Included. Cartridge cover not included
Is a adapter expensive and where would one be found? Is a cartridge cover important to have?
post #12 of 15 Old 04-10-2014, 07:32 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Heaven only knows. It should be a 10-cent plastic part.
No.
mcnarus is offline
post #13 of 15 Old 04-10-2014, 08:39 PM - Thread Starter
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
No.
Are you saying the adapter could be hard to find?
post #14 of 15 Old 04-10-2014, 10:29 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
Nah. You should be able to pick up a plastic 45-rpm adapter for $5 on eBay, or a nicer metal adapter for $10 or so. Assuming of course that a family member or friend doesn't have one lying around that they'd give you.
skriefal is online now
post #15 of 15 Old 04-11-2014, 07:48 AM - Thread Starter
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
No.
Thanks guys for your help and input. I haven't fully committed to getting a turntable I just wished all of the audio nirvana wouldn't be so costly.
Reply CD Players & Dedicated Music Transports
