My first turnable will be... - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By JumpingBean92
Old 04-09-2014, 08:58 AM - Thread Starter
fortisimo's Avatar
1) Audio Technica AT-LP120USB 290 € (with AT95E)
2) Pro-ject debut 3 260 € (with OM5E)
3) Stanton T.92 USB 290 € (with v500.3)
4) Reloop RP-4000M 290 € (with audiotechnica 3600) (arm is not adjustable in height)
5) Audiophony – TT 2930 225 € ( I do not know much about it)
I just want to play some LPs. I do not want to spend more than 350 € alltogether. I will not take the risk of second hand!
I am thinking to buy a separate phono preamp anyway and a usb interface in case I want to digitize tracks. No scratch...
fortisimo is offline
Old 04-09-2014, 09:42 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Either 1 or 2. Take your pick.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Old 04-09-2014, 10:42 AM - Thread Starter
fortisimo's Avatar
Is a usb connection nessesary in order to just play disks with AT-LP120USB? Is this statement wrong "The turntable can’t operate unless plugged into a power source and computer." from http://vinyl-converter-turntable-review.toptenreviews.com/audio-technica-lp120-usb-review.html
And what about the preamp that it has? Should I make the modification of removing this or this is not nessesary?
Old 04-09-2014, 01:01 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
That statement is dead wrong. Lots of people use that turntable without ever connecting it to a computer. The only reason you need to connect your turntable to a computer is if you want to digitize your vinyl.
It's OK, nothing more. But it's switchable. You can turn it off and feed the turntable into another preamp if you want.
mcnarus is offline
Old 04-09-2014, 03:51 PM - Thread Starter
fortisimo's Avatar
Many people suggest Shure M97XE.
Is this better than the AT95E? Should I ask the shop to change the AT95E with the Shure M97XE (if they can do so ofcourse...)
Old 04-09-2014, 04:18 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Yes.
mcnarus is offline
Old 10-29-2014, 05:03 PM
Quoted: 12 Post(s)
Liked: 2
If you can up your budget just a little bit to a Pro-Ject Carbon, it will blow all of these other tables clear out of the water.
auronihilist likes this.
JumpingBean92 is offline
Old 10-29-2014, 06:45 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
A gross exaggeration. It will presumably be marginally better than its predecessor (the Debut III), but on some measures (W&F, for certain), it cannot hold a candle to the AT120.
mcnarus is offline
Old 10-29-2014, 08:59 PM
njgl_torres's Avatar
Send a message via Yahoo to njgl_torres
hi
i got my Technics SL-5300 on craigslist. its build like a tank. almost 2yrs now never have a problem.
thanks
ID:	339713   Click image for larger version
njgl_torres is offline
Old 12-10-2014, 02:43 PM
arcada's Avatar
Liked: 0
Originally Posted by njgl_torres View Post
hi
thanks
Agreed, built to last.
arcada is offline
