turntable jumps when walking in, out and around room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 04-28-2014, 11:27 AM - Thread Starter
cdeath's Avatar
hi guys, i know this is probably a strange one. my turntable, a drive-based pioneer from the late 70s, is quite fragile. i live in a three story ex-council house with 3 floors. Our living room is on the second floor and some of the rooms have lodgers and there are communal spaces.
So my turntable is located on a hi-fi cabinet in the living room. it is quite prone to jumping if we sit in the sofa, or walk out the room, even when we try our best to be light footed!
just wondering if anyone has experienced this and what you have done to get round it? i am guessing it is because it isn't a solid floor but obviously we can't afford to go out and concrete all the floors!
thanks for reading :)
cdeath is offline
post #2 of 45 Old 04-28-2014, 11:38 AM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
I don't know if it is possible for you but I had the same problem and I took care of it by suspending it from the cieling. If you have people jumping around in the room above you it might not work. Mine was fine because the people upstairs from me when I lived there did not have kids jumping around all the time.
TCARCIO is offline
post #3 of 45 Old 04-28-2014, 11:44 AM - Thread Starter
cdeath's Avatar
Thats an interesting idea. There is a floor above with 2 lodgers so might not work. Do you have pics? I also thought about putting shelves into the wall, but its a stud wall so it might have to same problem...
Edit: Its a solid wall not stud so maybe?
cdeath is offline
post #4 of 45 Old 04-28-2014, 02:04 PM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
I don't have pics because it was about 20 years ago and I no longer live there. I just used anchors to attach hooks to the cieling then ran 4 pieces of chain down to a piece of plywood that was big enough to hold the turntable.
TCARCIO is offline
post #5 of 45 Old 04-28-2014, 02:21 PM - Thread Starter
cdeath's Avatar
And that stopped it moving? Didn't it move on the chains?
cdeath is offline
post #6 of 45 Old 04-28-2014, 02:39 PM
TCARCIO's Avatar
Quoted: 110 Post(s)
Liked: 95
Yes but not if I didn't bump it or move it for another reason. I could jump up and down and it would not effect it.
TCARCIO is offline
post #7 of 45 Old 04-28-2014, 02:50 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
Perhaps your stylus pressure is too light.
FMW is offline
post #8 of 45 Old 04-28-2014, 02:58 PM - Thread Starter
cdeath's Avatar
Thats pretty cool !
I think I've got the balance just right. Its generally fine otherwise. I can add more weight, but doesn't make a difference, just puts too much pressure on the record.
cdeath is offline
post #9 of 45 Old 04-28-2014, 05:15 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
You need an Isolation stand to cut down on the vibrations. Check w/ Timber Nation on line they have some nice stands in the $40 price range. This should alleviate the problem.smile.gif
Class A is offline
post #10 of 45 Old 04-29-2014, 12:54 AM - Thread Starter
cdeath's Avatar
Many thanks. Is there a UK equivalent do you know?
cdeath is offline
post #11 of 45 Old 05-01-2014, 09:53 AM - Thread Starter
cdeath's Avatar
cdeath is offline
post #12 of 45 Old 05-01-2014, 10:21 AM
Blindman0v0's Avatar
Quoted: 42 Post(s)
Yep, thats exactly what I did in the old days and it worked very well.
Blindman0v0 is offline
post #13 of 45 Old 05-01-2014, 12:01 PM - Thread Starter
cdeath's Avatar
Yeah unfortunately that won't work here. Currently I put an anti slip mat underneath which made a small difference. But I've now added a woolen blanket under the cabinet which so far seems to have worked... i keep finding myself bracing preparing for the skip though !
cdeath is offline
post #14 of 45 Old 05-01-2014, 01:26 PM
Quoted: 42 Post(s)
Does yours have the hydraulic filled feet? That helps quite a lot but its not usually enough for older homes. Certainly somebody makes an isolation stand for these now a days. I'm sure DJ's use some sort of an isolation system. You'll find a lot of them at ebay http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR4.TRC2.A0.H0.Xturntable+isolation&_nkw=turntable+isolation&_sacat=0&_from=R40
post #15 of 45 Old 05-02-2014, 03:59 AM - Thread Starter
cdeath's Avatar
It has slightly raised feet but hydraulic I dont think so. Ive put a woolen blanket under the cabinet and it works better. Will check out the isolation cabinets too :)
cdeath is offline
post #16 of 45 Old 05-02-2014, 10:03 AM
Quoted: 42 Post(s)
Some of those hydraulic feet are ridiculously expensive but it looks like you could get a nice set for less than $40.
post #17 of 45 Old 05-02-2014, 10:29 AM
donutfan's Avatar
Quoted: 18 Post(s)
I've never used one myself but on various audiophile forums I've read about wall-mounted shelves for turntables. I think they mount directly to the studs in the wall, avoiding the "bounciness" found in floor-based mounting solutions.
donutfan is offline
post #18 of 45 Old 05-10-2014, 10:34 PM
Class A's Avatar
Quoted: 295 Post(s)
Liked: 316
Check out Silent Stage. It's a British company that makes TT Isolation Platforms. Prices are reasonable.smile.gif
Class A is offline
post #19 of 45 Old 05-11-2014, 10:57 AM - Thread Starter
cdeath's Avatar
Awesome thank you :)
cdeath is offline
post #20 of 45 Old 05-14-2014, 04:42 PM
mediaace's Avatar
I solved my problem with that issue years ago and even though I've moved many times since, the problem never resurfaced.  Put the entertainment center with the turntable against an OUTSIDE wall rather than an inside wall.  The floorboard planking is anchored better against an outside wall, which is a SOLID wall, usually made of brick and mortar or poured concrete.  Inside walls tend to be made of wood and sheetrock or horsehair plaster and don't give the floorboard planking the same support as an outside wall.
mediaace is offline
post #21 of 45 Old 05-15-2014, 03:53 AM - Thread Starter
cdeath's Avatar
The inside wall it is against is also a solid wall, but I see what you are saying. I have though about moving it to the outside wall, but not sure with the layout of the room. WIll keep pondering though. So far putting the cabinet on top of a woollen blanket seems to have done the trick though.
cdeath is offline
post #22 of 45 Old 05-15-2014, 09:32 AM - Thread Starter
cdeath's Avatar
I added 2 layers of foam underneath the record player, but it still jumps when sitting on the sofa. I am now trying it on the outside wall corner to see if that makes a difference. Lots of jiggling stuff around! Would it make a difference that my record player is current on TOP of my unit? What if I put it inside? Would that make a lot of difference or no?
cdeath is offline
post #23 of 45 Old 05-16-2014, 01:05 AM - Thread Starter
cdeath's Avatar
I've moved the turntable, kept the foam and put it inside the cabinet. I've also removed the blanket. It's not perfect but better than it was so thanks for the suggestion =). Plus it allows me to connect the TV too in this position. I guess my next attempt would be an Isolation cabinet in place of what I have.
cdeath is offline
post #24 of 45 Old 05-16-2014, 08:53 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 251
I would think some of this may be your foam being too stiff? The TT is not very heavy so it would tend to transfer the floor movement.
The outside wall suggestion works as that wall sits on a solid foundation. Your inside wall may or may not be sitting on a solid foundation wall especially if you have raised floors so it too will have movements in it transferred to the TT.
May want to find some very soft foam but thick enough that the TT will not sink into it and contact the shelf or compress the foam so it is in essence becomes hard and transfer that vibrations.
CharlesJ is offline
post #25 of 45 Old 05-16-2014, 09:20 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Or has anyone tried these on a record player: http://www.amazon.com/Sorbothane-Hemisphere-Non-Skid-Adhesive-Durometer/dp/B003IMODW8/ref=cm_cr_pr_product_top
As a matter of fact I recently tried those as a heavy footstep (mine) near the tt caused a skip so thought I'd put them to the test....total failure, these things made it much worse. Much worse. Plus hard due to shape and the stock feet on a Technics SL1200mkII to get it aligned properly (i.e. each foot staying in line with the sorbothane thingy), but even once aligned properly still much more sensitive to floor vibration. Kinda disappointed as the sorbothane stuff is actually supposed to work....now I just checked the ad details from your link and I swear when I bought it I swear the ad copy said a weight of 17-24 lbs, now it says 17-24 lbs per foot so maybe just not a match. I guess I need a much heavier tt....
lovinthehd is offline
post #26 of 45 Old 05-17-2014, 01:45 AM - Thread Starter
cdeath's Avatar
Well the foam is quite soft (not overly), the turntable is also quite heavy (the plate in particular) so it sinks slightly but as i say it needs to be a lot better where it is, further away from floor movement and only really jumps if you fly into the settee and cause the whole floor to wobble!
Yeah I saw a review on there with someone saying it didnt work for their turntable, plus its pretty expensive stuff...
cdeath is offline
post #27 of 45 Old 05-17-2014, 09:44 AM
jsmiddleton4's Avatar
Quoted: 589 Post(s)
Liked: 199
If sitting on the couch causes your turntable to jump either your floor suspension needs some serious attention or dude, you need to lose weight. There is no good reason a properly balanced turntable should be THAT sensitive.
E.B. White said, "I arise in the morning torn between a desire to improve the world and a desire to enjoy the world. This makes it hard to plan the day."
jsmiddleton4 is online now
post #28 of 45 Old 05-17-2014, 09:52 AM - Thread Starter
cdeath's Avatar
Lol I definitely don't need to lose weight... I weigh 11 stone and i'm 6ft 2! Nah it only jumps if I PROPER jump on the sofa. Sitting down doesn't. It used to before I moved it to where it is now. To be honest its an old council house, the floor boards aren't going to be great, but as we don't plan to be here forever we can't justify getting the floor sorted.
cdeath is offline
post #29 of 45 Old 05-17-2014, 10:55 AM - Thread Starter
cdeath's Avatar
Ok i might have another reason for the jumping... today I took the cartridge off to clean the stylus and noticed it had snapped, but was still attached. As I went to put it back, it snapped off completely (through no force I should add). So I've ordered a new cartridge :)
cdeath is offline
post #30 of 45 Old 05-17-2014, 01:13 PM
CharlesJ's Avatar
Quoted: 425 Post(s)
Liked: 251
... To be honest its an old council house, the floor boards aren't going to be great, but as we don't plan to be here forever we can't justify getting the floor sorted.
One more thought on this. I think you have a crawl space under that room and most of the house. Check out how easy it is to get under that room. I would but a beam under the joists and prop it either with a short screw jack on a pier, or two or just 4x4 cripples tightly fit. Not expensive and may be worth it for your duration of stay.
CharlesJ is offline
Reply CD Players & Dedicated Music Transports
