I'm involved in a thread at PF about certain members there not understanding the mechanics behind computer based audio as it pertains from getting material over Ethernet.
Some are adamant that they can tell a difference in Ethernet that passes spec. So I offered up the following and want to see if their are any potential holes in the method for testing an individuals ability to simply discern a difference reliably:
My offer to the person(s):
A computer with two identical network cards. One card has what ever passes spec CAT5/6/7 you want (I would assume AQ would pass testing or we could take Kurt at BJC up on his offer to send one of your choice for validation) and one of his cables or other certified CAT6. You bring your cable and I'll bring mine.
Set card A up with static ip, as example, 192.168.10.20/24, card B s 192.168.10.21/24, NAS as 192.168.10.22/24.
Setup as a typical network: NAS> GB Switch> Card A / Card B (identical cards)>USB to DAC.
I would bring a Windows PC with fresh install of Win 7 X64.
Media Monkey / Foobar / JRiver with WASAPI or ASIO. Your choice. We can discuss play list and how you want them setup.
Use a Wyred DAC ~$1600 ( let me know if Wyred is unacceptable ). Connected via your choice of USB cable.
You indicate to me when to roll the dice. I would simply enable or disable a network interface in Windows(or not). I wouldn't be in the room to do this. Just setup RDP and I would control from a 3rd network controller on a separate physical network (directly cabled most likely for efficiency of setup) so no network bandwidth taken up on the Card A / Card B / NAS segment.
1 day
RDP only requires 5.6Kpbs (same as old 56k dial up modem speeds) for trivial screen sharing tasks.
Loser purchases the DAC for the winning party. I could be in Chicago in ~ 4 hours. Your system. 15 rolls of the dice. Even # Card A odd # card B. Hit 13 out of 15 (86%). I'm not even asking you hit an A letter grade. Initial roll will determine if Card A or B starts the evaluation session.
1 day
