Nad C516BEE vs Nad C546BEE as a transport - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-25-2014, 11:10 PM - Thread Starter
trion20001's Avatar
Hi All,
Was wondering if anyone had any feedback or opinion on which player would make a better CD Transport. The other choice I had was using the Tascam CD-200 or CD-500.
Thanks for any and all feedback!
trion20001 is offline
post #2 of 4 Old 06-26-2014, 02:22 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
I can't find anything that would motivate me to buy either one, let alone one over the other.
Virtually any Blu-Ray player will play the same formats, play a lot more formats and even cost less.
FMW is offline
post #3 of 4 Old 10-16-2014, 06:39 PM
Liked: 0
Originally Posted by trion20001 View Post
Hi All,
I was doing the same comparison at first and then realized what was just said. I run music from a USB thumb-drive from the front of my Blu-Ray player (Sony). I run the output of the S/PDIF, and sounds better than any other method I have tried so far, and that includes direct USB to the Integrated Amp (NAD 390DD). I just hate having to use a method that I find a convoluted solution and wanted something more streamlined. I like those Bluesound Vaults, it will accept CDs, store them for you, and also has a DAC if you need it and a good GUI.
D.
chezrock is offline
post #4 of 4 Old 10-16-2014, 06:42 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
The short answer is neither.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Reply CD Players & Dedicated Music Transports
