ARTT DSDMate (Plugin) for Foobar, Another sacd_extract GUI Tool - AVS Forum
post #1 of 1 Old 08-08-2014, 01:49 AM - Thread Starter
Liked: 0
Hi, i did a little tool and share it with Foobar2000 & DSD lovers.
DSDMate (Plugin) for foobar integrated sacd_extract and foorbar2000 together. Now you can extract DSD files from SACD-ISO image directly in foobar2000 environment. Special thanks for Mr. Wicked who is the developer of sacd_extract project.
Ready Features:
Extrcat DSD/DSF Native and DST(Lossless Compression) files.
Output CUE Sheet and SACD-DISC information file.
Channel and Track-Splitter are Configurable.
Support all and individual track extraction.
The latest sacd_extract 0.3.7 (Win32) embedded.
Notice:
Always set current user as member of Administrators and close UAC under Windows 7/8.
DSDMate Plugin needs the support of vcredist_x86, you should get and install it first.
Tested on Windows XP/7 (32bit) and beta for Win8 (or 64bit).
Here is the details: http://www.arttlabs.com/artt/blog
AudioMate is offline
Reply CD Players & Dedicated Music Transports
User Tag List
