Powerbook As DAC w/OSX10.4.11 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-16-2014, 10:55 AM - Thread Starter
nickm11's Avatar
Hi
A friend gave me an old powerbook that run OSX 10.4.11 and I'd like to turn it into a DAC that can work with my good audio system.
I'd appreciate any info on best sounding software and maybe even hardware tips. I know Amarra is probably a good place to start, but is there a version that works on OSX10.4?
Thanx
Kinergetics KCD40 and KCD 20/40
Robertson 6010 & 4010
Chiro C800
Kinergetics Subwoofer
Martin Logan Aerius I
Sony SMP-N100 Network Media Player w/iSedora
nickm11 is offline
post #2 of 8 Old 08-17-2014, 08:47 AM
dscottj's Avatar
Quoted: 210 Post(s)
Liked: 127
I use my laptop for private/portable streaming with headphones. For awhile I used the built-in DAC with my Macbook Pro (2013 model). Then I got an Audioquest Dragonfly 1.2 DAC/amplifier. HUGE sound quality improvement. For playback and control I use XBMC running in a window. Because all my audio files (ha!) are in FLAC, I also use XBMC when I burn CDs.
That's how I do it. I'm sure others will have different ideas.
dscottj is offline
post #3 of 8 Old 08-17-2014, 12:01 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
This'll work, and iTunes should work just fine, unless it is missing features you need (like handling FLAC). Unless the PB has noise issues (and you'll only know once you hook it up), the only hardware you'll need is a cable.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #4 of 8 Old 08-17-2014, 05:53 PM - Thread Starter
nickm11's Avatar
Thanx for the info, but I know programs like Amarra increase the sound quality. Only problem, Amarra only works with intel Mac's and this is a G4.
I was hoping to find a program that would do something like Amarra for a G4
Chiro C800
nickm11 is offline
post #5 of 8 Old 08-17-2014, 06:03 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
And how do you know that?
mcnarus is offline
post #6 of 8 Old 08-17-2014, 06:41 PM - Thread Starter
nickm11's Avatar
I did some homework. I'm asking intelligent forum members like you for ideas and info.
Chiro C800
nickm11 is offline
post #7 of 8 Old 08-17-2014, 07:35 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Well, I gave you some info. You didn't want it. That's fine with me. Good-bye.
mcnarus is offline
post #8 of 8 Old 08-24-2014, 06:42 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
Just so you understand, you can't improve the sound of digital music. The sound quality is locked in the data in which it is encoded. It is a bit stream not waveforms. You can alter the sound after conversion. But calling it different would be more accurate than calling it better. Better is a matter of preference.
What you need to look for is a software equalizer that works with the sound system in your computer. That will allow you to alter the sound yourself to your own preference. I'm not an Apple user so I'm not familiar with available software but now you know what you are seeking.
FMW is offline
Reply CD Players & Dedicated Music Transports
