what is a good DSD and SACD player for less than $1500? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 57 Old 01-22-2016, 06:22 AM - Thread Starter
happy hopping's Avatar
Quoted: 58 Post(s)
I am trying to find the spec. of Pioneer PD-70, but even w/ the google search engine, I can't find the pioneer elec. web site that allows me to read more about this player.
Some other player, plays DSD, but does not seems to support SACD, for e.g.:
TEAC PD-501HR says it does NOT support SACD
http://audio.teac.com/product/pd-501hr/specifications/
so the only ones left is the Pioneer PD-50 or PD-70, which supports SACD, but since I can't see the spec., don't know if the drive can play DSD disc
There is the Sony XA5400ES or the XE800, but those are 7 yr. old and I can't find the spec. of it neither.
any suggestion?
happy hopping is offline
post #2 of 57 Old 01-22-2016, 01:13 PM
thebard's Avatar
Quoted: 86 Post(s)
Liked: 50
thebard is offline
post #3 of 57 Old 01-22-2016, 01:17 PM
LexInVA's Avatar
Quoted: 469 Post(s)
Liked: 189
Sony has a new media player coming out soon that does the whole array of audio from CD to high-res digital downloads and everything in-between. It was shown off at CES.
LexInVA is offline
post #4 of 57 Old 01-22-2016, 07:29 PM - Thread Starter
Quoted: 58 Post(s)
the oppo is a bit "vague", on the DSD part. After I post the above, I found this from Pioneer:
http://www.pioneer-audiovisual.eu/eu/node/191
You can see under "PLayback Media / format""
it explicitly said SACD
DSD disc
because DSD is a technology, and a disc format.
So Oppo didn't explicitly said it can read DSD disc
anyhoo, being too lazy to start another thread, what is decoding the disc signal? the SACD / DSD player or the DAC (I use Emotiva)
how does that work?
post #5 of 57 Old 01-22-2016, 09:30 PM
thebard's Avatar
Quoted: 86 Post(s)
Liked: 50
DSD disc
how does that work?
I have an Oppo 93 and a modest (not huge, but does include hybrid/multichannel/dsd discs) collection os SACDs. The Oppo has played everything I've thrown at it.
There is an option in the setup to bitstream audio to the receiver, or to decode on the player and output PCM.
There is generally a high customer satisfaction with the Oppos, excellent support, and a decent ROI when the next models come out & people sell/upgrade. I've heard of very few people being disappointed with their purchase.
thebard is offline
post #6 of 57 Old 01-23-2016, 01:10 AM - Thread Starter
Quoted: 58 Post(s)
I agree the Oppo is a very good quality player. I have re-read that 2nd link. It clearly shows "it supports the DSD signals" but there is no spec. that shows it supports DSD disc
You see, any CD player can play SACD or DSD disc, it's just that it won't decode the "extra" w/i SACD or DSD disc that's all.
post #7 of 57 Old 01-27-2016, 01:01 PM
gbaby's Avatar
Quoted: 541 Post(s)
Liked: 173
I think any of the Sony blu-ray players will play SACD/DSD and their advantage over the Oppo is that the Sony plays SACD in PCM at 176.4 whereas the Oppo plays SACD in PCM at 88.2. Look for the Sony player that can play DSD through its HDMI output. Many can be purchased in the $100.00 range.
gbaby is offline
post #8 of 57 Old 01-27-2016, 01:32 PM
poochpa's Avatar
Quoted: 31 Post(s)
The Oppo 103 and 105 will play the dsd layer of a SACD and can output the dsd audio as bitstream digital or PCM. The 103/105 can also play dsd files in either .dsf or .dff formats from an attached external drive.
poochpa is offline
post #9 of 57 Old 01-28-2016, 10:55 PM
acebreathe's Avatar
Quoted: 166 Post(s)
Liked: 96
I have an Oppo 103-D and as Poochpa says it will play back the DSD layer on a SACD over HDMI and also playback DSD downloads.You need to go in to the set up menu and choose how you want to play back the discs. I also have a Sony model, can't remember which one, that will play DSD from a SACD over HDMI. Keep in mind that whatever pre pro or AVR you are feeding has to be able to handle it. To me the biggest advantage the Oppo has over the Sony is the inclusion of analog outputs. If your pre- pro or AVR does not jhandle DSD over HDMI and you have analog jacks you can use them. I'm not sure the Sony will handle a DSD file from a USB drive or a HDD.
acebreathe is offline
post #10 of 57 Old 01-29-2016, 05:48 AM
commsysman's Avatar
Quoted: 907 Post(s)
Liked: 501
Most CD players will NOT play SACD discs.
Some "dual" SACD discs also have a regular CD layer in them that can be read by regular CD players, but a disc that is SACD only will be unreadable.
commsysman is offline
post #11 of 57 Old 01-29-2016, 05:49 AM
commsysman's Avatar
Quoted: 907 Post(s)
Liked: 501
any suggestion?
The OPPO BDP-103 is only $499 from OPPO, and it will read and play ANYTHING!!!
post #12 of 57 Old 03-10-2016, 10:10 PM
thehun's Avatar
Quoted: 583 Post(s)
Liked: 470
It's SACD, not DSD disc. DSD is the file format SACD use. CD players can only read the redbook [PCM] layers of hybrid SACDs. Oppo players are playing SACDs for about 10 years now. The current crop of BD players can also playback DSD downloads via USB. They can decode, or passthrough to a downstream device. It won't get any more versatile than this. I don't know what specs you re looking for, but they play all currently available discs that labeled "SACD" period.
De sagittis Hungarorum libera nos, Domine!
The Hun
thehun is offline
post #13 of 57 Old 03-10-2016, 10:29 PM
CaTaSTrOphiK's Avatar
Quoted: 14 Post(s)
Get the Oppo. Depending on your other equipment the 105 may be worth the jump.
CaTaSTrOphiK is offline
post #14 of 57 Old 03-10-2016, 10:57 PM - Thread Starter
Quoted: 58 Post(s)
Originally Posted by thehun View Post
It's SACD, not DSD disc. DSD is the file format SACD use. CD players can only read the redbook [PCM] layers of hybrid SACDs. Oppo players are playing SACDs for almost 15 years now. The current crop of BD players can also playback DSD downloads via USB. They can decode, or passthrough to a downstream device. It won't get any more versatile than this. I don't know what specs you re looking for, but they play all currently available discs that labeled "SACD" period.
I know that. And that's good, but as I said, I need a player that specifically play DSD disc, not just decode DSD format, in this case, the Pioneer PD-50 or PD-70 does the job
post #15 of 57 Old 03-11-2016, 01:44 AM
thehun's Avatar
Quoted: 583 Post(s)
Liked: 470
And who sells such discs to begin with? I had to do a search and came up pretty empty. DSD discs are basically DSD image without Sony's DMR and encoding. No wonder there is virtually no support for them.
The Hun
thehun is offline
post #16 of 57 Old 03-11-2016, 02:51 AM - Thread Starter
Quoted: 58 Post(s)
I have hundreds of CD albums in DSD
http://www.yesasia.com/us/search/dsd...h_TW/list.html
post #17 of 57 Old 03-11-2016, 03:17 AM
thehun's Avatar
Quoted: 583 Post(s)
Liked: 470
That explains quite a bit.
The Hun
thehun is offline
post #18 of 57 Old 03-11-2016, 01:01 PM
ematcion's Avatar
Quoted: 76 Post(s)
Liked: 107
Those are just CDs remastered using DSD technology. I don't know about the DSD CDs originating from China, but there are legitimate CDs remastered with DSD coming out of Hong Kong (Hong Kong Sony Music is one of 5 Sony Music divisions around the world with its own DSD remastering facilities, which provide remastering services to HK Universal Music and HK Warner Music). Domestically, US Sony Music remastered many Elvis Presley album using DSD, along with its CBS Masterworks titles.
Avatar - My guard dog, Bogi
Part of my ever-growing SACD collection
ematcion is offline
post #19 of 57 Old 03-12-2016, 01:05 AM - Thread Starter
Quoted: 58 Post(s)
and those are the ones I bought: DSD from HK, Germany and Japan.
I don't buy any music CD from china.
So, besides Pioneer or Sony, I don't know any other brand who actually have players that plays actual DSD disc
post #20 of 57 Old 03-12-2016, 09:40 AM
merv43's Avatar
Quoted: 12 Post(s)
I would recomend the Sony XA5400ES if you can find one. I picked one up on ebay for $900 and it is an incredible cd/sacd player. To my ears it is just a tad better than my Oppo 103D with sacd and way better playing cd's.
Mike
merv43 is offline
post #21 of 57 Old 03-12-2016, 05:28 PM
dbphd's Avatar
Quoted: 353 Post(s)
Liked: 134
My Ayre C-5xeMP plays DSD, and it sounds superb. I don't know if they have any current players that do, though.
2channel8 likes this.
dbphd is offline
post #22 of 57 Old 03-12-2016, 10:23 PM - Thread Starter
Quoted: 58 Post(s)
YOur Sony come out in 2008, and I wonder if it's better than the Pioneer PD-70 or PD-50, which came out 2012.
post #23 of 57 Old 03-12-2016, 11:16 PM
NorthSky's Avatar
Quoted: 6841 Post(s)
Liked: 3415
any suggestion?
Yes, Oppo BDP-105 → Official OPPO BDP-105 Owner's Thread
• Bonus: http://www.stereophile.com/content/n...vMxR5iwHXPZ.97
Other reads of interest:
http://www.theabsolutesound.com/arti...dsd-downloads/
http://www.head-fi.org/products/ques.../reviews/11230
Official OPPO BDP-105 Owner's Thread => Read the full page.
http://forums.stevehoffman.tv/thread...-discs.224579/ => Read the full thread, it's only two pages.
___________
• SACD - The BDP-105 plays Super Audio CD (SACD) and supports both stereo and multi-channel high resolution audio programs. Users can select whether to output the DSD (Direct Stream Digital) signal in its native format or convert it to PCM.
http://www.oppodigital.com.au/blogs/...led-dsd-format
~ Bob
"And it stoned me to my soul"
- Van Morrison
NorthSky is offline
post #24 of 57 Old 03-12-2016, 11:34 PM - Thread Starter
Quoted: 58 Post(s)
I check that 1 out already, it doesn't support DSD disc format
post #25 of 57 Old 03-12-2016, 11:59 PM
NorthSky's Avatar
Liked: 3415
Bummer! And I thought that the Oppo 105 was a universal and versatile CD/SACD/DSD/HDCD/DVD-Video & Audio/BR-Video & Audio player.
And it doesn't play UHD Blu-ray discs either. But that one (true 4K) is coming up in their next replacement...later on this year or next...depending of the popularity of the new 4K UHD BR discs (it's the new wave, the new rage, where the money is all emphasized, for the studios and manufacturers, plus the stocks/investments...market).
Then for your DSD discs get this one (that you already mentioned above): http://www.pioneer-audiovisual.eu/eu/node/191
Because the latest Oppo players (105 & 103) missed few formats here: https://www.oppodigital.com/hra/dsd-by-davidelias.aspx
__________
Question for you: Do you burn DSD discs?
http://www.ps3sacd.com/dsddiscguide.html
~ Bob
- Van Morrison
NorthSky is offline
post #26 of 57 Old 03-13-2016, 12:46 AM - Thread Starter
Quoted: 58 Post(s)
YOu think incorrectly. There is no DSD above.
There is no DSD on that spec.
http://www.oppodigital.com/blu-ray-b...-Features.aspx
look under Diversified Media Support as well as Additional Disc & Media Formats -
You see the word DSD disc format anywhere?
post #27 of 57 Old 04-07-2016, 08:50 PM
JA Fant's Avatar
Quoted: 183 Post(s)
Liked: 218
Marantz DV9500/ 9600 ?
JA Fant is offline
post #28 of 57 Old 04-08-2016, 12:10 PM
ematcion's Avatar
Quoted: 76 Post(s)
Liked: 107
I am still trying to figure out what is a DSD disc.
acebreathe likes this.
ematcion is offline
post #29 of 57 Old 04-09-2016, 01:41 PM
postrokfan's Avatar
Quoted: 477 Post(s)
Liked: 2735
That's because it's typically referred to as SACD.
HT/Living room: FR/FL Sierra 1 NrT, Sierra-1 NrT Center, B&W ASW610, Yamaha RX-A2030, Oppo BDP-93, ATV.
2-channel: B&W 804D, B&W ASW608, Parasound P5, Parasound A23, Marantz CD5004, Rega RP1, Bluesound Node2.
postrokfan is offline
post #30 of 57 Old 04-09-2016, 07:42 PM - Thread Starter
Quoted: 58 Post(s)
no, similar but not quite. SACD has DSD encoding build in. But DSD disc is not the same as SACD disc
Reply CD Players & Dedicated Music Transports
