Car CD Players; Do they output at "Line Level?" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-10-2017, 09:49 AM - Thread Starter
Tom Kay's Avatar
Quoted: 20 Post(s)
Hello;
I haven't found a CD player for home use that stores/plays 5 CD's and that is narrow enough to fit into a 12 inch wide space. I do not have room for a 5 CD turntable. I would like to solve this, and I'm ready to go to semi-extreme lengths.
There are modern car stereo systems that allow loading of 5 or 6 CD's and then sequential or random playback. What about using a car stereo as a home CD player? I could easily create a 12 VDC power supply. My question would be, is the output at a typical household level known as "Line Level?" I mean adequate for the usual RCA wires and jacks. LP players, for example, are much lower level output, so they have to be pre-amped just to get to line level output.
I would take the line level signal from the car CD player, and jack it into an amp that has RCA inputs. Even the Sonos Connect-Amp has 1 set of RCA inputs.
Anyone know if a car CD player is line level output?
Thanks, Tom.
There's a proper time and place for spontaneity, dammit!
Tom Kay is offline
post #2 of 8 Old 02-25-2017, 08:14 PM
Liked: 8
Yes they are line level
Depending on which one you are looking at they usually range from 2v-5v
NC25T is offline
post #3 of 8 Old 02-28-2017, 05:16 AM - Thread Starter
Tom Kay's Avatar
Quoted: 20 Post(s)
NC25T;
Thanks for the feedback. I just want to make sure, does "Line Level" have an international standard, like for example, 2 volts? The range of 2 to 5 volts seems a bit large. My concern would be hitting the amp inputs with more power than they should see.
Cheers, Tom.
Tom Kay is offline
post #4 of 8 Old 02-28-2017, 10:36 AM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1139
In the distant past line level meant about -10dBV or 1/3V. When CD came out the RBCD standard was 2Vrms for 0dBFS signals. That then became a defacto standard for a lot of gear and most CDPs. But as Sony/Phillips don't control the market anymore manufacturers can go their own way, hence the variation.
At line level, it's voltage not power. When you get the unit, measure the outout with a 0dBFS tone at 50 or 60Hz with even a cheap DVM and it will be accurate enough. If it's too high, then insert a voltage divider (2 x 5c resistors/ch) to drop it to where you need it.
A9X-308 is offline
post #5 of 8 Old 02-28-2017, 11:55 AM - Thread Starter
Tom Kay's Avatar
Quoted: 20 Post(s)
Thanks A9X-308;
I guess the next challenge would be to choose a car CD player/changer, and look inside to isolate which wires carry the "line level" signal to the amp section. This isn't a home audio unit, so there won't be any jacks out from the unit, intended to plug into an amp/receiver.
Cheers,
Tom Kay is offline
post #6 of 8 Old 02-28-2017, 12:54 PM
A9X-308's Avatar
Liked: 1139
Thanks A9X-308;
A pleasure.
Cheers,
Why not choose one with pre-outs?
A9X-308 is offline
post #7 of 8 Old 03-01-2017, 05:49 AM - Thread Starter
Tom Kay's Avatar
Quoted: 20 Post(s)
All part of the learning curve. Didn't know such a beast existed.
Thanks again, Tom.
Tom Kay is offline
post #8 of 8 Old 03-01-2017, 10:34 AM
A9X-308's Avatar
Liked: 1139
Thanks again, Tom.
They certainly do exist and have for a long time. They cater to those who want to use more powerful amps than the head units provide or to the rare user that will go active and use a line level xover and 1ch/driver to the speakers.
A9X-308 is offline
Reply CD Players & Dedicated Music Transports
