How good is the ipod's DAC? - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 187 Old 04-22-2009, 09:19 AM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
Originally Posted by Chu Gai View Post
That's all fine and well krabapple, but does it have PRAT?
Of course -- accompanying Atkinson's bench test report there's a full-fledged subjective review, by some Stereophile prat.
krabapple is offline
post #182 of 187 Old 06-30-2009, 11:32 PM
dbailey100's Avatar
Originally Posted by cavchameleon View Post
There is one, but a bit pricey. The WADIA 170ITransport. It's an iPod dock that outputs a digital bitstream (coaxial) and component video output.
http://www.listenup.com/lu/merchant....s&Store_Code=l
Instead of using my Nano, I'm using an Apple TV to listen to music. The Apple TV is connected to my receiver via HDMI and the signal to my receiver is PCM. I'm guessing that my receiver's DAC is being used since the incoming signal is digital. Unlike the iPod dock unit for my receiver, Apple TV displays the album art and song information on my TV! And in 1080p. So far, I like using Apple TV more than an iPod dock.
Happy 4th of July everyone!
cheers!
dbailey100 is offline
post #183 of 187 Old 07-06-2009, 11:49 AM
cnstarz's Avatar
my friend says that the ipod sounds like crap compared to CDs because the ipod only has a 1bit DAC as opposed to a 24bit DAC in his headunit.
cnstarz is offline
post #184 of 187 Old 07-06-2009, 08:52 PM
krabapple's Avatar
Quoted: 385 Post(s)
Liked: 374
But the 1-bit DAC has a higher sampling rate, SO THERE. Your friend loses the number game.
post #185 of 187 Old 07-07-2009, 05:16 AM
D. Lundberg's Avatar
The iPod does not use a 1 bit DAC, it has a stereo codec with "24 bit" multi-bit Delta-Sigma DACs.
And I don't think your friend understands how a DAC works. That a DAC is labeled 24 bit only means that it accepts 24 bit signals, it does not mean that it works with 24 bits internally.
They usually (like the one in the iPod) work with just a few bits, but at very high speeds.
So both the iPod and your friends head-unit use "24 bit" DACs, but that does not tell us anything at all about their sound.
D. Lundberg is offline
post #186 of 187 Old 07-17-2009, 03:52 PM
TunerHead's Avatar
Sorry if this was already mentioned, but the only product made to bypass the ipod dac and analogue output is the Wadia unit that runs about $350, otherwise...
TunerHead is offline
post #187 of 187 Old 05-08-2010, 05:01 PM
Joshjp's Avatar
Quoted: 13 Post(s)
Liked: 115
Originally Posted by JimOfoakCreek View Post
To be honest I am quite happy with the performance of my 5.5G 80GB iPod. I absolutely love it but you know how audiophiles are. Nothing is ever good enough! When we get something in our heads it's hard to think objectively.
Having said that, I will be making a DIY iPod dock-to-RCA cable just for grins. ;-)
its the best ipod in my opinion i got the new 160 gig ipod and it sounds like **** compared to the 5.5 g
HT~
PANASONIC TC-P50ST60, OPPO BDP-103D, ONKYO TX-NR818, PANAMAX MR4000, KLIPSCH RF-62's, RC-62, RS-52's, PSA TRIAX
2.1CH~
ADAM AUDIO F5's, EMOTIVA STEALTH DC-1, SVS SB-2000
Joshjp is offline
Reply CD Players & Dedicated Music Transports
