Optical vs Coaxial - AVS Forum | Home Theater Discussions And Reviews
post #1 of 64 Old 04-02-2007, 12:00 PM - Thread Starter
Zues's Avatar
Just curious if anyone else can tell a difference between these two. To me optical sounds way better. I have a nice monster cable coaxial cable vs a ultra thin optical cable that came with a satelite box. No comparison the optical sounds way better. And it's the thinnest cable i've ever seen. Xm satelite also sounds amazing via satelite-optical.
Also curious for cd playback if anyone prefers digital, i run analog interconnects but am starting to doubt myself if digital is not better.
Zues is offline
post #2 of 64 Old 04-02-2007, 12:35 PM
Targus's Avatar
Then you have a broken coax cable. No cable, optical or coax, can change the way the analog signal sounds, once it's been decoded and converted from a digital bitstream.
Targus is offline
post #3 of 64 Old 04-02-2007, 12:38 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Sounds better in what way?
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #4 of 64 Old 04-02-2007, 12:56 PM
ssteel01's Avatar
Not even Cardas?
But seriously...
It's an apples to oranges comparison. The analog outs will use the CD player's DAC, the digital out will use your receiver's DAC. Whether or not that will translate into an audible difference....that's where the really fun debates start.
Scott
ssteel01 is offline
post #5 of 64 Old 04-02-2007, 12:59 PM - Thread Starter
Zues's Avatar
My center sounds much better, less boomy and dialog seems much cleaner, more tolerable, less distracting.
Zues is offline
post #6 of 64 Old 04-02-2007, 01:28 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Has this change required a recalibration on your part?
Chu Gai is offline
post #7 of 64 Old 04-02-2007, 01:48 PM - Thread Starter
Zues's Avatar
Not really, it just sounds better. Same result on two different receivers, two different dvd players. Movies on the optical connection via satelite always sounded better than my dvd player with coaxial. Using optical on the dvd player sounds as good or better now than satelite. Another test i did while ago i compared optical vs coaxial and with different speakers, i couldnt really tell a difference, putting my ear to the speakers though you could hear more noise from the coaxial. Anyways those are my findings, however much bs you might find them to be
Zues is offline
post #8 of 64 Old 04-02-2007, 02:00 PM - Thread Starter
Zues's Avatar
Scott
I find with the analog outs the db's arent as loud at a given level than digital connection. Warmer sound, maybe less detailed. For sure a difference, whether it's the dac or the analog interconnects i dont know, i would guess the analog connection.
Thats a nice system, btw ssteel.
Zues is offline
post #9 of 64 Old 04-02-2007, 02:20 PM
hugh9269's Avatar
It also depends what has a better DAC and what is the better component.. If you receiver is of better quailty than your CD player use the optical, if it the other way use a coaxial cable. Again as noted above your preference of sound comes into play.
hugh9269 is offline
post #10 of 64 Old 04-02-2007, 02:43 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 104
You are talking an optical digital output, as compared to a single, coax digital cable, correct? They should sound identical.
jdcrox is offline
post #11 of 64 Old 04-02-2007, 02:44 PM - Thread Starter
Zues's Avatar
Just did another test, this time both optical and coaxial hooked up to the dvd player switching back and fourth. No difference.
Something can be learned here though, you dont have to buy a expensive, thick, shielded coaxial cable. A ultra thin, cheapest optical will be just as good.
Zues is offline
post #12 of 64 Old 04-02-2007, 03:03 PM
Targus's Avatar
So, now there's no difference? In your OP, there was a huge difference....
Targus is offline
post #13 of 64 Old 04-02-2007, 03:34 PM - Thread Starter
Zues's Avatar
You thought i was serious
Zues is offline
post #14 of 64 Old 04-02-2007, 03:51 PM
Targus's Avatar
No, your opening post is the funniest thing I've ever read.
Targus is offline
post #15 of 64 Old 04-03-2007, 10:03 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Suddenly, I have no idea what this thread is about anymore.
Chu Gai is offline
post #16 of 64 Old 04-03-2007, 10:10 AM
Targus's Avatar
Originally Posted by Nuthed View Post
Trying to kill another thread I see.
Attempting to start another fight, I see.
You never have anything to add, why do you post?
Targus is offline
post #17 of 64 Old 04-03-2007, 11:49 AM
Nuthed's Avatar
Why do you suggest this? Coax and optical are both digital.
Either connection would use the receiver's DAC.
Nuthed is offline
post #18 of 64 Old 04-04-2007, 08:03 PM
KBI
KBI's Avatar
Digital RCA is superior IMO..Better fit.. Less prone to jitter.. & Optical can only sample rate from 48kHz to 96kHz, & will become unreliable or non functional at higher sample rates..(192kHz) Digital Coax has no problem with high sample rates like 192kHz..
The #1 spot for gaming headphones/headsets/Mic mods/DH 5.1/links & more.
http://www.facebook.com/?ref=home#!/...494101?sk=info
KBI is offline
post #19 of 64 Old 04-04-2007, 08:12 PM
KBI
KBI's Avatar
The music is still digital regardless if you just use analog interconnects.. Your CD player has a DAC..Digital to analog converter, that converts the 0'1's on the CD, to lush, warm audio.. The only true analog sources I know of is Vinyl & FM radio.. I could be wrong though..
KBI is offline
post #20 of 64 Old 04-05-2007, 11:27 AM
Forte_II's Avatar
Sounds like a ground issue. Optical does not make any kind of electrical connection hence no possible ground issues sneaking in.
Yamaha RX-A700, Samsung BD, Sonos Connect Carver M-400X powering My DIY front mains (2 Vifa PL17's, Vifa XT25 with 3rd order HP, 2nd order LP (4th order LR acoustic)). Samson 1200 powering a pair of Dayton RSS 15 HF subs in 4.5ft sealed cabs.Still have (bought in 1993) the Klipsch RC- 7center and a pair of Bose 305's that were laying around from somewhere...
Forte_II is offline
post #21 of 64 Old 04-16-2007, 03:20 PM
rdad's Avatar
I have what is most likely a stupid question. Can optical cable be run around sharp corners? Or will the glass in it break? For example, running it tightly against the corner of adjoining walls (90 degree turn).
rdad is offline
post #22 of 64 Old 04-17-2007, 11:33 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
If you mean a hard right angle, no. There's a minimum bend radius that you should be able to obtain from the manufacturer.
Chu Gai is offline
post #23 of 64 Old 04-17-2007, 01:48 PM
crna59's Avatar
Wrong answer... I use SC and ST optical for DSD and 192/24 Mastering. Optical cable is not prone to RF interference. Optical cable is better... end of story.
Bruce
crna59 is offline
post #24 of 64 Old 04-17-2007, 03:41 PM
machani's Avatar
Bruce
Depends on what kind of optical - single core plastic versus multi-core glass/fiber optic. I have a $15 multi-core glass toslink which outperforms a $20 Monster interlink plastic toslink.
C N Machani
machani is offline
post #25 of 64 Old 04-17-2007, 04:20 PM
rdad's Avatar
Thanks for the response Chu Gai. I really appreciate it.
rdad is offline
post #26 of 64 Old 04-18-2007, 10:06 AM
QueueCumber's Avatar
Quoted: 70 Post(s)
Liked: 38
Optical and Coaxial both send digital bitstreams (1s and 0s) encoded in their respective signal carrier types (light and electrical signals respectively). The cable itself won't make any difference. It is possible that the optical signal is being skewed as it is turned back into an electrical signal from a light signal, that there is damage to one or the other of the two cords, or that there is some timing aberrations between the two due to the two previously mentioned potential problems (as well as excessive bending in the optical cable causing light to fall outside the angle needed for total internal reflection), but hopefully if you have a half-decent system (probably even the cheapest system does it nowadays) it will cache and reclock the bitstream in some way. If you were bending the cable too much you would know it, as you likely wouldn't hear anything (unless audio optical is spread spectrum... in which case you would likely get static and some audio - Of this I'm not certain as I specialized in Networking Computer Science not in Audio Networking, though I doubt they would use spread spectrum in something like an audio device because of the added unnecessary complexity/costs).
As far as digital vs. analog in CD output, it really depends, to me, on what you eventually have decoding the digital signal into analog... At some point a piece of equipment is doing the same thing in both cases. Having the digital signal converted to analog as close to the speaker as possible is always an advantage, as it is very difficult to skew a digital signal (it takes a lot to skew one, and there are excellent algorithms for error correction when it does occur), while skewing an analog signal is many times easier (though you can greatly reduce the risk by using balanced cables - this won't help with signal attenuation however). Ultimately though, you reduce the risk most by using digital up until the last moments before audio output.
QueueCumber is offline
post #27 of 64 Old 04-19-2007, 10:32 PM
DefiantGSR's Avatar
When connecting a CD player w/ RCAs to the receiver, will it always use the CD player's DACS? Or will it sometimes use the receiver's DACs?
I'm planning to get a high quality CD player and connecting to my receiver and don't want to get a new integrated amp.
DefiantGSR is offline
post #28 of 64 Old 04-20-2007, 06:58 AM
Quoted: 70 Post(s)
Liked: 38
It depends. Some receievers will allow you to bypass processing, some won't. Also, it depends on whether you are using the RCAs from the analog or digital outputs of the CD player as well (I'm assuming analog, since you mention plural RCAs and are talking about a CD player, not a multichannel source player...).
post #29 of 64 Old 04-20-2007, 08:39 AM
DefiantGSR's Avatar
What would this feature be called on receivers? (the ability to bypass processing)
I'm currently looking at the onkyo 605 that's coming out. Thanks much for your help
post #30 of 64 Old 04-20-2007, 09:12 AM
ssteel01's Avatar
Usually called "Direct" or "Analog Bypass"...something to that effect. Don't know if that receiver does it or not though.
Just FYI, if you're using any EQ to smooth out frequency response in the room, it may get bypassed in a true analog direct mode.
Scott
ssteel01 is offline
Reply CD Players & Dedicated Music Transports
