PS3 as a CD Player - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 129 Old 06-24-2010, 12:55 PM
aztlan67's Avatar
Hello everyone , recently I upgraded my AV/R and since then when I play any CD it seems I lost my bass ,my setting for audio on PS3 where as follows HDMI then automatic configuration for blu-ray view, change from bitstream to LPCM to send PCM signal to receiver, on music settingS I tried MP3 and AAC, and now on regular or burn cd's only, I can't figure why there is not enough bass , any help please
aztlan67 is offline
post #122 of 129 Old 06-26-2010, 07:28 AM
tbtom's Avatar
Do you have a subwoofer? Are your speakers set to "large" or "small"? I would check out the PS3 thread under Blu-ray Players.
tbtom is offline
post #123 of 129 Old 07-13-2010, 07:44 AM
UNCHeelYeah's Avatar
Hi all,
I have noticed that when using my PS3 as a CD player, when I select a track, the first second or so is eliminated from that track. From that point on, if I let the CD play straight through, the other tracks aren't affected; however, if I manually select another track, then the omission occurs again.
I am using HDMI Sony premium cable, through a NAD T785HD A/V receiver. I have two bridged NAD C272's running from the preamp section of the 785 for listening to music in stereo mode. Prior to hooking up the two C272's I had the same issue just using the PS3 through the 785 by itself.
Anyone else ever experience this issue, and know what can be done to remedy it? The sound is quite excellent, but missing the first few seconds of a track that is manually selected is annoying.
UNCHeelYeah is offline
post #124 of 129 Old 07-27-2010, 04:35 PM
Brien's Avatar
Quoted: 89 Post(s)
Liked: 24
Originally Posted by razel View Post
Finally! After 3 years, there are no more surprizes for HDMI audio output. Firmware 3.1 finally resolves the multichannel issue. If your reciever supports multichannel up to 5.1 or 7.1 @ 176k when you play any music it will output with the correct number of channels. Before 3.1, the PS3 will output 5.1 or 7.1 @ 176k for 2 channel upsampled music. Now it will output 2 channels @ 176k without having to do the workaround.
Is there some sort of setting I need to switch? When I put in a 2ch CD, it always sends it as multi-track PCM to my AVR. I'd love to be able to send it to my receiver as 2ch. PCM.
Brien is offline
post #125 of 129 Old 07-28-2010, 12:51 PM
razel's Avatar
Quoted: 13 Post(s)
Assuming it's PS3 with firmware 3.1 or greater connected HDMI to your receiver. Some people had luck with having the PS3 redetect capability of the audio receiver. Also ensure 44.1, not 48k is set in the music setting and also check that the surround processing is off or set to 'straight' on your receiver.
razel is offline
post #126 of 129 Old 08-16-2010, 02:06 PM
bradman's Avatar
Quoted: 29 Post(s)
Liked: 33
My Yamaha 661 automatically disables processing and goes to "Straight" when I play CDs at 176.4khz.It won't let you apply any soundfields or processing at all.
bradman is offline
post #127 of 129 Old 09-16-2010, 01:59 PM
Ryan Peddle's Avatar
I am experiencing the same thing. When I listen to music, I prefer to only use my front towers (Paradigm Studio 100 v5, connected to NAD M25, so plenty of power).
When I listen to music via cd, mp3 stored, or lossless stored, there is drop off in bass output.
Yet when I watch a movie and play it in stereo mode with the sub off, I still get great bass.
I am starting to think the PS3 is crappy for music audio quality for bass.
Custom Home Theater Sales Specialist.
Newmarket, ON.
Ryan Peddle is offline
post #128 of 129 Old 05-04-2014, 09:44 AM
zorro21's Avatar
Hey guys, I know this thread is old but hopefully someone can help me out.
I have a 1st gen (Fat) PS3 and whenever I play an audi CD on it, I can only hear music coming out of one side of my soundbar. I'm sure there is a setting that I'm overlooking that would permit the audio to come out from 2 channels.
Here's my equipment:
Player: Fat PS3
Receiver: Pioneer elite vsx60
Soundbar: Episode 300 (3 channel)
PS3 and receiver are hooked via HDMI.
Any help would be greatly appreciated, thank you!
zorro21 is offline
post #129 of 129 Old 05-12-2014, 12:20 PM
Phantom Stranger's Avatar
Quoted: 414 Post(s)
Liked: 307
Player: Fat PS3
It's almost certainly a setting in your receiver that is causing the problem, unless your soundbar has gone bad on one side.
Blu-ray Picture Quality Tiers (updated through July 13, 2017)
Phantom Stranger is offline
Reply CD Players & Dedicated Music Transports
