Revised IBOC power calcultor is now available (NPR Labs) - AVS Forum | Home Theater Discussions And Reviews
Old 11-17-2009, 10:18 AM - Thread Starter
briank101's Avatar
This is an updated version (Nov 17 2009) which allows greater power increase compared to its earlier NPR Labs calculator released in July.
It's available here http://www.nprlabs.org/publications/...nce/index2.php
It's not officially released yet but I found I can enter the station and get allowable power increase information. The data may not be fully correct yet as I believe they are populating the database as we speak. But the detailed info in the Results section seems to indicate quite a few station will get the full 10 dB increase (10X the digital power) This is wonderful if that's the case
briank101 is offline
Old 11-17-2009, 12:11 PM - Thread Starter
briank101's Avatar
Appears to be offline again but here's the results for WHOM FM which I captured earlier.
IBOC Candidate Station
Call Sign
WHOM
IBOC Power Limit (dBc)
upper
lower
WHOM
MOUNT WASHINGTON,NH
Results where station WHOM is the Proponent Station Candidate Call Sign: (reserved band)
Candidate Application ID:
Candidate Class:
Candidate Channel: (47.9MHz)
1st UPPER Adjacent Call Sign: WBAR-FM (LAKE LUZERNE,NY)
1st UPPER Adjacent Application ID:
1st UPPER Adjacent Class: A
1st UPPER Adjacent Channel: 234 (94.7MHz)
Bearing, in Degrees True...
From Candidate Station to 1st Adjacent Station: 241
Distance (kilometers)...
IBOC Power Limit: -10.0dBc
Candidate Class:
1st UPPER Adjacent Call Sign: WVTQ (SUNDERLAND,VT)
1st UPPER Adjacent Channel: 236 (95.1MHz)
From Candidate Station to 1st Adjacent Station: 229
Old 11-18-2009, 09:52 AM
G.B.'s Avatar
I can not wait to test the signal after increase. Wish they could Help AM - HD more to...
G.B. is offline
Old 11-19-2009, 12:52 PM - Thread Starter
briank101's Avatar
It's up again at http://www.nprlabs.org/publications/...nce/index2.php
This time they have better data. Here's a screeenshot of WILV 100.3 FM Chicago which would have the full 10 dB increase on both sidebands.
