XDR-F1HD connection question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-28-2009, 07:42 PM - Thread Starter
mdovell's Avatar
I think I might get this soon (price dropped again) I just want to make sure I get this right.
I already have a decent antenna (archer color eagle..oldie but goodie)
If I get this
http://www.amazon.com/exec/obidos/tg...l/-/B0000AJ692
would it work in tangent with this
http://www.radioshack.com/product/in...odsInSession=1
I know it isn't the best speaker in the world.
I just thought the rca input would go into the radio and the input of the speakers would go into this other.
mdovell is offline
post #2 of 5 Old 12-01-2009, 11:33 PM
W1KNE's Avatar
That Amazon link brings me to the home page.
However what I think youre asking is about the output of the XDR-F1HD.
It is line level only, you will need to have an amplifier to speakers or amplified speakers for it.
--Mike Fitzpatrick
Broadcast Engineer
Put your boots on folks, it's getting pretty deep in here!
Note: opinions and advice given here are mine and mine only.
W1KNE is offline
post #3 of 5 Old 12-04-2009, 05:14 PM - Thread Starter
mdovell's Avatar
Well. if the output can go to rca cables can I plug in an rca to a line in converter cable and then to speakers? I'm just trying to figure out how to use speakers on this without a a receiver.
mdovell is offline
post #4 of 5 Old 12-04-2009, 06:23 PM
fastl's Avatar
Quoted: 22 Post(s)
Use "powered" speakers. Try searching websites like bswusa.com, sweetwater.com, guitarcenter.com. Generally, any of the websites that cater to professional audio types or musicians will have them.
fastl is offline
post #5 of 5 Old 12-18-2009, 07:26 PM
Seanraff's Avatar
Go to the Goodwill store and buy a set of old computer speakers, I got a nice set of Bose with the Sub for $5.00!
You will have to adapt the stereo single pin plug on the computer speakers to twin RCA plugs, put that is easy, if worse comes to worse, get out your wire strippers and soldering iron.....
Seanraff is offline
Reply HD Radio
