Is it possible? Factory to HD in a flash? - AVS Forum | Home Theater Discussions And Reviews
Old 02-20-2011, 12:05 AM - Thread Starter
humblejohn's Avatar
autotoys.com told me that I could convert my 2005 toyota camry factory radio to HD as well as aux and usb connections with some sort of converter that they sell. I am a newbie and haven't the faintest idea how this could be done.
Can this be done for about $100 or what are my choices if any?
Will the sound quality be good? etc.
In other words, I can get the above features run through my factory radio. Sounds too good to be true. Is it?
thanks in advance.
humblejohn is offline
Old 02-20-2011, 06:38 PM
Jim1348's Avatar
Quoted: 117 Post(s)
Maybe they are referring to the JVC KTHDPK1 Transportable HD Receiver with Car Kit.......................
http://www.radioshack.com/product/in...ductId=2991655
Jim1348 is offline
Old 02-20-2011, 08:01 PM
oc-rdx's Avatar
thanks in advance.
Probably one of these:
http://www.hdradio.com/buyers_guide.php?prime=autonow
oc-rdx is offline
Old 02-21-2011, 04:39 PM
Audball's Avatar
Yes they do sell converters/gateways for factory radios. If you have a factory radio with a Satellite button, you will be able to see HD Radio info (artist/title info). The converter emulates a factory Satellite tuner which plugs into the Satellite port of your factory radio. Some converters have a pass thru option to connect both your factory satellite tuner and HD Radio tuner. Some even have an aux input/ IPOD hookup. Look for brands like iSimple, Axxess, and PAC Audio. I have one in my Honda Ridgeline and I love keeping the factory look and hate having aftermarket parts stick out like a sore thumb.
There are some cons though.... My Isimple gateway will not allow more than 6 presets. My steering wheel radio controls now have a mind of their own (changing stations only). You got to do your homework and see what works with your car's factory radio the best.
Audball is offline
