Insignia NS-03 comparison - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-06-2012, 05:53 PM - Thread Starter
W1KNE's Avatar
How would you guys compare the Insignia NS03 to the NS01 portable HD?
Does the NS-03 decode RDS?
Is the sensitivity and selectivity as good as the NS01?
--Mike Fitzpatrick
Broadcast Engineer
Put your boots on folks, it's getting pretty deep in here!
Note: opinions and advice given here are mine and mine only.
W1KNE is offline
post #2 of 3 Old 03-06-2012, 08:13 PM
bigtomNJO's Avatar
It doesn't decode RDS, and its not as selective or sensitive as the 01 in my experience (or my unit is just a fluke).
*sorry for the bad info earlier*
bigtomNJO is offline
post #3 of 3 Old 03-23-2012, 02:57 PM - Thread Starter
W1KNE's Avatar
Hi Tom,
Your unit may be a fluke. It does decode RDBS. Side by side, my NS-HD02 is out performing the NS-HD01 by 3x. The NS-HD01 on 107.1 MHz and other frequencies, here, you hear over load from the big local FM signals (92.3, 93.3, 94.1, 95.5, 105.1). The NS-HD02 I don't hear anything like this with it. I can hear weak signals on NS-HD02 that I can't NS-HD01. It locks in HD about as good as the NS-HD01 does. The NS-HD01 decodes RDBS quicker than the 02. The 02 needs a stronger signal to see RDS on it too.
-- Mike
--Mike Fitzpatrick
Broadcast Engineer
W1KNE is offline
Reply HD Radio
