WLTJ HD-4 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-17-2012, 07:12 PM - Thread Starter
radioagogo's Avatar
I was sitting in my office today and I was looking at one of my retired computers that I streamed the station through and I thought "let's give it one more job" so I installed it in one of my racks connected a Sangean HDT-1 HD Radio to it and I'm feeding my HD-4
so for a little while maybe a week, you can hear my actual HD off-air feed, remember this is HD-4 and it is HD encoded for 24kbps
I'm streaming using winamp's shoutcast so it will connect easly to that and VNC, and I'm sure a few others
http://69.95.45.82:2000/listen.pls
radioagogo is offline
post #2 of 3 Old 08-26-2012, 06:53 AM
bigtomNJO's Avatar
Audio sounds good - artifacts are not as obnoxious as on other streams, and the processing is aggressive enough to match the music. Would add a touch of reverb, but that's just my personal preference in general.
PS - the "Q In The City" automation seems screwey...just played the same song twice (S.O.S Band - Take Your Time (Do It Right)).
Good job on keeping all the HD channels on the air!
bigtomNJO is offline
post #3 of 3 Old 08-27-2012, 09:14 PM
mgpt6's Avatar
Stereo seperation is good. Is the processing used the same as Freeform BCN on CBS owned WZLX-HD3 in Boston? Shocked you can get stereo that does sound half decent on only 24 kbps.
mgpt6 is offline
Reply HD Radio
