HD channels in Minneapolis, MN - AVS Forum | Home Theater Discussions And Reviews
Old 08-10-2014, 09:06 AM - Thread Starter
Anode's Avatar
Quoted: 30 Post(s)
Not sure if there is a seperate thread for Minneapolis HD or not but I didn't find it so here goes.
I recently got a used Sangean HDT-1X and while I am able to get a few HD channels I am unable to get 99.5 (Classical) and 97.1 (Cities97). What could be the reason for that ? I live in a southwest suburb. Does anyone else in the area get these channels on HD ?
I am able to get 89.3 and 91.1 which are sister stations of 99.5. The lowest hd signal strength I get is in 107.9 (cool108). I have tried an indoor ribbon dipole antenna but no luck.
If these channels do exist and people are able to receive it then could it be that they are broadcasting in a format that the radio does not support ?
Please advise.
Anode is offline
Old 08-12-2014, 07:38 AM - Thread Starter
Anode's Avatar
Quoted: 30 Post(s)
strange thing happened..just to see if I can get any benefit from the TV antenna in the attic I plugged the coax of the tv antenna in the radio. I picked up all the stations I was expecting which is not the surprising part. What happened next has left me scratching my head till now. Then I removed the tv antenna and plugged in the "wire" antenna that I used before and voila I still get the same stations with practically no difference in signal strength. Its as if plugging in the tv antenna made the radio flip a switch. The only difference is that the tv antenna had a proper RF F-type connector and the wire antenna has just a plug that looks like an f-type but its really not, its more like a rca type but fits perfectly in the radio antenna socket.
Could it be that there may have been some problem in the radio's antenna socket and inserting the coax somehow fixed it ?
Anode is offline
Old 08-16-2014, 10:55 AM
tylerSC's Avatar
Quoted: 675 Post(s)
Liked: 155
Possibly you did not have a secure connection the first time you hooked up the indoor antenna. As overall the Sangean has a good tuner. And good luck you had finding one of those tuners as they are now hard to come by. But one thing you may consider for better reception. Get a good splitter and connect the better TV antenna to both the TV and the HD Radio tuner. You should get stronger radio reception and more signals that way. The indoor antennas are likely not as good, especially for distant stations.
tylerSC is offline
Old 08-16-2014, 05:19 PM - Thread Starter
Anode's Avatar
Quoted: 30 Post(s)
That is what I was going to do as well but funny thing is the indoor wire antenna is as good or even better on some stations than the tv antenna in the attic. and that is based on the CNR readout on the radio. The tv antenna is actually just a single element dipole (diy 12" each side) and works pretty good on vhf and uhf. Perhaps it does not have any gain on fm or perhaps it has severe impedance mismatch or high swr on fm band.
The indoor antenna is the fm antenna that came with my HK 3490 receiver.
Anode is offline
Old 08-22-2014, 09:28 PM
Jim1348's Avatar
Quoted: 102 Post(s)
HD Channels In Minneapolis, MN
It is great to see a fellow Minnesotan discussing HD radio. I really don't use mine much anymore. I did enjoy the comedy format several years back. I think it was on 93.7-2. Unfortunately, towards the end before they changed formats, they seemed to have the same comedy loop that played over and over!
Jim1348 is offline
Old 10-27-2014, 05:59 PM
Fast351's Avatar
Quoted: 12 Post(s)
In the Twin Cities here too. I have an HD tuner in my truck, and am still looking for a good one for at home. I like the 107.9-HD3 channel, which I think is the KOOL 1-0-80s that was on the 97.1 HD2 carrier for a while this summer.
Listening right now on my Insignia NS-HD01 which has a nearly dead battery but seems to work OK tethered to a USB cable.
Fast351 is offline
Old 02-28-2015, 11:34 AM - Thread Starter
Anode's Avatar
Quoted: 30 Post(s)
Lets talk about audio quality of local hd stations. I am going to call/contact a couple of stations tomorrow but I'd like to get others feedback too. Recently I bought a good avr (Marantz SR7007) and was very disappointed with the audio quality of hd fm. The biggest problem is the heavily compressed low bandwidth type of sound. Its annoying. Most stations are equally bad and I can speak about 97.1 and 94.5 which I listen to most often. However, whats interesting is that 99.5, 89.3 and even 91.1 (all mpr) sound very good. So that tells me that its probably the studio engineers and operators that are screwing this up big time.
I am curious if I am the only one who thinks the sound quality of almost all stations on the dial sucks or is it really the case ? Please chime in with your experience and opinions.
Anode is offline
Old 02-28-2015, 02:13 PM
Jim1348's Avatar
Quoted: 102 Post(s)
Originally Posted by Anode View Post
.....I am curious if I am the only one who thinks the sound quality of almost all stations on the dial sucks or is it really the case ? Please chime in with your experience and opinions.
No, you are not the only one. Sadly, I have pretty much given up on BOTH HD Radio and Mobile DTV. I have equipment for both of them, but the outlook for each is equally dismal.
I think sending an email to the Engineering Department is a great idea! I have contact some of the local DTV broadcasters in the past and I have found them to be very receptive, no pun intended, of listeners who offer helpful feedback.
Jim1348 is offline
Old 03-01-2015, 02:49 PM - Thread Starter
Anode's Avatar
Quoted: 30 Post(s)
I wrote to them lets see what happens. I think telling the bad stations about the better stations would be a good strategy. Who knows maybe it might stir their ego and respect and they might do something about it. Conversely giving positive feedback to the stations that are doing it right or at least not as bad woud be good too.
This is actually nothing different than reception reports that shortwave broadcasters used to seek from listeners (SWLs - short wave listeners they were called) and the station would send back an acknowledgement in return called a "QSL" card. Sometimes other goodies too. Ham radio lingo.
Anode is offline
