KABC on KLOS-HD3? - AVS Forum
post #1 of 12 Old 05-08-2007, 07:35 PM - Thread Starter
k2koq's Avatar
I see it listed but...
Anybody actually hear KABC on KLOS-FM-HD3
k2koq is offline
post #2 of 12 Old 05-09-2007, 01:15 AM
rwagoner's Avatar
Yes. Low fidelity but decent. Sounds better on AM HD, but AM HD still can't be heard at night.
rwagoner is offline
post #3 of 12 Old 05-09-2007, 04:54 AM
Mike Walker's Avatar
If the bitrate is 32kbps, it ought to sound EXACTLY LIKE AM HD. Same codec, same bitrate. At a lower bitrate, it ought to sound worse.
Mike Walker is offline
post #4 of 12 Old 05-09-2007, 09:59 AM
Master Theseus's Avatar
Actually there is a new codec technology that HD Radio is implementing so that 12KB/s HD signal when broadcasting voice can sound as good as 36KB/s. It was originally being used in cell phones to help improve voice communication trunk lines.
I have heard this. It does sound OK. I have received it in HD AM and it does sound good.
Master Theseus is offline
post #5 of 12 Old 05-09-2007, 11:07 AM
mattdp's Avatar
Great. Can't wait for the 48kb/s lossless compression?
http://rochestermnhd.blogspot.com/ - Tech 55901. Tech news for Rochester. Authored by mattdp and gjvrieze.
http://tvfmantennas.a.wiki-site.com/index.php/Hardware
mattdp is offline
post #6 of 12 Old 05-09-2007, 12:52 PM
One thing, Master, and this is critical. Remember the large "B" as in KBPS means "Bytes". The small "b" as in kbps means bits. There are eight bits per byte, so 128KBPS is actually eight times more than 128kbps.
post #7 of 12 Old 05-09-2007, 01:22 PM
CKNA's Avatar
32kbps is AM HD stereo. Mono AM HD is 20kbps and that is what most stations are on AM band.
CKNA is offline
post #8 of 12 Old 05-09-2007, 01:36 PM
mattdp's Avatar
I thought mono HD was 24kbps.
mattdp is offline
post #9 of 12 Old 05-09-2007, 01:42 PM
How can they use a new codec? Is the firmware field upgradable on HD radios? I thought the codec was locked in...a part of the standard.
post #10 of 12 Old 05-09-2007, 02:30 PM
From my understanding they can upgrade firmware (codec) OTA! What a thought! At least they were experimenting with great success.
post #11 of 12 Old 05-09-2007, 06:35 PM
rwagoner's Avatar
Should, but doesn't. It's as if they use a differently-processed feed. Much lower in total volume as well.
rwagoner is offline
post #12 of 12 Old 05-10-2007, 04:40 AM
Then my bad, rwagoner. I should have said that it SHOULD sound identical. Obviously your mileage may vary
Reply HD Radio
User Tag List
