Any advice on indoor FM antennas? The Crane?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 06-11-2007, 10:32 AM - Thread Starter
BillGill's Avatar
I have a new Boston Acoustics Receptor HD Radio listening in Atlanta where I get great reception with maybe ten HD stations. But I hate the Mickey Mouse wire antenna [what is this, the 1940's?] so I would appreciate advice on an indoor antenna for a ground floor apartment. I've tried a rabbit ears with so-so results.
Any one with experience with the Crane?
BillGill is offline
post #2 of 17 Old 06-12-2007, 02:26 AM
doxytuner's Avatar
For me the $100 Crane Antenna was unsatifactory since it was very directional, needed ac power, and did not perform well. The best one I could find is the Magnum Dynalab Silver Ribbon FM Antenna for $35. It does not need AC power and performs well but don't expect it to perform as well as an outdoor antenna. You'll buy it at www.magnumdynalab.com or at www.audioadvisor.com.
Richard
doxytuner is offline
post #3 of 17 Old 06-12-2007, 05:12 AM
R.F. Burns's Avatar
Does your building have a master TV antenna? Most apartments do and I'd suggest that it would be your best bet for good reception. There is usually a jack somewhere in the living room which allows you to connect a TV set to. By the way, I am guessing you are using the dipole which came with the radio. Any decent tuner comes equiped with a dipole. I use the dipole lying on the floor (My radio came with the wire stub when I bought it in 2006, but Boston Acoustics sent the dipole to those of us who had already purchsed the radio free of charge) and it works fine for me. I'm 24 miles north of NYC.
R.F. Burns is offline
post #4 of 17 Old 06-12-2007, 05:56 AM - Thread Starter
BillGill's Avatar
... lying on the floor? I never thought of that.
Say more?
BillGill is offline
post #5 of 17 Old 06-12-2007, 10:09 AM
doxytuner's Avatar
If I were you I would try all three-Master antenna( It may have an FM block), dipole, and Magnum. My guess is that the Master Antenna would be best if there is no FM block and next the Magnum, and last the dipole.
Richard
post #6 of 17 Old 06-12-2007, 06:57 PM - Thread Starter
BillGill's Avatar
Richard, thanks for your good advice. Today I ordered the Silver Ribbon from Audio Advisor [two weeks for delivery] and I'm very curious to see if it helps.
The Master Antenna is an external-outside antenna, right? It's not going to work for my ground floor apartment, not unless I can hang it in the window.
Bill
BillGill is offline
post #7 of 17 Old 06-12-2007, 08:21 PM
doxytuner's Avatar
The Master Antenna is an exterior antenna with cable running to each apartment ending with a connector or connectors in each apartment. If you cannot find any connectors in your apartment you do not have a Master Antenna serving all the apartments. Also you could have connectors in your apartment for cable TV or Satellite TV. In any event if you find any connectors hook up your HD radio and see what happens. Get whatever you need from Radio Shack for the hook-up-it will not be expensive. If you find no connectors then just wait for your Magnum Antenna.
Richard
post #8 of 17 Old 06-14-2007, 12:05 AM
dnewhous's Avatar
Richard
What antenna are you talkinga about? C Crane makes AM antennas.
I have not tried them but a couple of other brands to look at for omni FM antennas are Fanfare and Antenna Performance.
dnewhous is offline
post #9 of 17 Old 06-14-2007, 07:35 AM
Mike Walker's Avatar
I think he's talking about the "FM Reflect" antenna from C Crane. I LOVE C Crane, and have made lots of purchases from them. But the pictures on their website showing the Reflect being bent into a variety of shapes, AND STAYING THAT WAY, are pure BS. The antenna is FLOPPY. Bend it for circular polarization, and it flops straight down at the ground as soon as you let go.
Mike Walker is offline
post #10 of 17 Old 06-14-2007, 12:03 PM
Carnivore's Avatar
The Silver Ribbon is just a glorified rabbit ears and should provide about equivalent reception. Its main advantage is that it looks nicer than your standard rabbit ears where decor matters.
Carnivore is offline
post #11 of 17 Old 06-14-2007, 06:30 PM
doxytuner's Avatar
[quote=dnewhous]What antenna are you talkinga about? C Crane makes AM antennas.
I have not tried them but a couple of other brands to look at for omni FM antennas are Fanfare and Antenna Performance.[/QU
I purchased the Crane Twin Coil Ferrite Am Antenna a while back and forgot it was AM and not FM.
Richard
post #12 of 17 Old 06-22-2007, 10:20 PM - Thread Starter
BillGill's Avatar
While I was checking out the Fanfare, I ran into the Terk FM 50
[I know, I know its a TERK] which is bannered as an indoor/outdoor antenna -
what do you think? The blurb says it can be mounted on an indoor wall.
http://www.amazon.com/gp/product/cus...ustomerReviews
BillGill is offline
post #13 of 17 Old 06-22-2007, 10:59 PM - Thread Starter
BillGill's Avatar
One more: the Bic Beam box. Has anyone actually
owned/used one of these?
BillGill is offline
post #14 of 17 Old 06-23-2007, 02:38 AM
dnewhous's Avatar
I've been told that antenna is unusable for HD, the two issues being noise created by the amplifier and (not sure if this applies to this particular model) the need to maintain a coaxial cable connection all the way from the anteanna to the tuner.
dnewhous is offline
post #15 of 17 Old 06-26-2007, 03:13 PM - Thread Starter
BillGill's Avatar
How about the Fanfare or the Magnum Dynalab ST-2 antennas?
They look the same and cost the same.
Anyone owns one?
BillGill is offline
post #16 of 17 Old 06-26-2007, 08:58 PM - Thread Starter
BillGill's Avatar
I just did a search here and found many good answers to the repetitous questions I have had [sorry about that] - I've read nothing but good comments about both of these antennas. Bill
BillGill is offline
post #17 of 17 Old 06-27-2007, 05:18 AM
While I agree with Carnivore that the Silver Ribbon SHOULD provide about the same gain as rabbit ears (and it's indistinguishable with analog fm), in reality, it pulls in quite a few more stations. I didn't believe it myself, until I repeated the test. And then repeated it again. Every time I reverted to rabbit ears, some stations "went away"...or at least their HD signals did. I am at a loss to explain why it performs better (more surface area maybe? The elements are VERY wide) It just does. I've yet to find someone who has made an actual comparison and disputes my findings. I'd actually like to be proven wrong, because I HATE it when things that science tell us SHOULD perform exactly the same DON'T!
Reply HD Radio
