Sangean HDT-1X west of Boston - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-27-2007, 10:04 PM - Thread Starter
jhe
jhe's Avatar
Radio is great. Didn't try much AM but did one station during thunder and got no interference.
For FM HD radio lists 17 Boston stations. I got 16 stations but one was Worcester and another was not on the list.
1 on the list: WCRB had strong FM signals but no sign of HD?
Another WUMB was too full of multipath with flashing HD and signal meter jumping all over 8 to 16.
The other missing station was WNEF 91.7 which could be too weak to get out to suburbs. I couldn't get the FM either.
The not on list station I did get was WERS at 88.9.
Only analog outputs for now. Sounds as good on FM or better than my other tuners. And the HD works good here for the most part. May be good on all when I play with my antenna more.
jhe is offline
post #2 of 8 Old 06-27-2007, 10:41 PM
jr_tech's Avatar
Check out the FCC data on WNEF , only 1 KW and the signal is all vertical:
http://www.fcc.gov/fcc-bin/fmq?list=0&facid=93889
Here is the coverage map:
http://www.fcc.gov/fcc-bin/FMTV-serv...FM1102728.html
Could be a challenge!
jr_tech is offline
post #3 of 8 Old 06-28-2007, 07:43 AM - Thread Starter
jhe
jhe's Avatar
Thanks jr_tech,
I may try rotating my FM antenna for that one!
jhe is offline
post #4 of 8 Old 06-28-2007, 08:34 AM
R.F. Burns's Avatar
Originally Posted by jhe View Post
Thanks jr_tech,
Remember, you loose about 20 DB of signal when you use an antenna not properly polorized and most likely your antenna is horizontal. They're using vertical for better mobile (automobile) coverage.
R.F. Burns is offline
post #5 of 8 Old 06-28-2007, 09:58 AM
mcocorochio's Avatar
jr tech,
Thank you , thank you. for that link. I love stuff like this.
Any way, back to the mention of WCRB in Lowell MA. It was one of the few reasons I purchase an HD radio. I was disappointed in Everett with roof antenna in that I could not get the digital signal. With -2 stations I get about 30 channels in Boston. This is about 85% or so of any lists that I've seen.
After looking at the coverage map for this station I think I should be able to receive it. ( I get the analog ok). My roof TV antenna seems to be pointed about 95 degrees southwest of Lowell (non rotating). I notice the ERP is listed at 37 whatevers. Should I be able to receive this at 25 miles?
Thanks for the link again (i'm going to have fun for a while with this),
Mike Cocorochio
mcocorochio is offline
post #6 of 8 Old 06-28-2007, 11:29 AM
jr_tech's Avatar
Mike C.
You are so welcome!
It sounds as if your antenna is pointed about Southwest... optimum for the station in Lowell would be more like Northwest (heading about 330 degrees or so). Many antennas have a sharp null off of the side (at 90 degrees) so that *might* be your problem.
Looking at the Application list on the FCC site, for WCRB:
http://svartifoss2.fcc.gov/cgi-bin/w...ility_id=23441
it appears that they have filed for several STA (special temporary authority) for their FD (digital) operation, which *might* indicate that they are not operating as they should be in some way. It could also just be indicating that they consider digital operation a "test".
Some stations connect their digital transmitter to their "standby" antenna, which may be much lower on the tower, or even a different tower, and may provide a weaker signal than is possible with a more "normal" configuration, where the analog and HD signal are emitted from the same antenna structure. Of course, if the analog transmitter needs to use the "standby" antenna for some reason, the digital is turned off... Bummer!
You might want to call the station to see if they are indeed transmitting in digital at this time!
hope this helps
jr
jr_tech is offline
post #7 of 8 Old 06-28-2007, 06:36 PM - Thread Starter
jhe
jhe's Avatar
Good news for Boston HD owners. WCRB responded to my email and the HD broadcasts are temporarily off the air. They are waiting for parts at the manufacturer and expect to be back on the air soon.
jhe is offline
post #8 of 8 Old 06-29-2007, 04:37 PM
vfrjim's Avatar
Patiently waiting for WEEI (103.7)
Support C-band, the only true satellite signal, More information HERE
vfrjim is offline
Reply HD Radio
