Sangean HDT-1X Review - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 07-17-2007, 09:01 PM - Thread Starter
Carnivore's Avatar
There is a comprehensive review of the HDT-1X up on Brian Beezley's site:
http://ham-radio.com/k6sti/hdt-1x.htm
Carnivore is offline
post #2 of 23 Old 07-18-2007, 08:33 AM
doxytuner's Avatar
Brian's review of the HDT-1X is extraordinary and gives us the pluses and minuses. It's unfortunate that he was not the design engineer of this unit.
Richard
doxytuner is offline
post #3 of 23 Old 07-18-2007, 10:46 AM
Master Theseus's Avatar
Richard
He was not, but he was a key figure in the development of some of the features and fixes of bugs.
His information has prooved invaluable to us and I hope that we can do more work together in the future.
Master Theseus is offline
post #4 of 23 Old 07-18-2007, 11:21 AM - Thread Starter
Carnivore's Avatar
Just curious, what happened with the analog AM section in the 1X where the NRSC deemphasis was removed (while by contrast it was present in the HDT-1)? That seems to be his biggest criticism of the new version, along with the tracking error in the AM tuner.
post #5 of 23 Old 07-18-2007, 01:00 PM
doxytuner's Avatar
Brian's criticism is much more than you suggest. Look at:
http://ham-radio.com/k6sti/hdt-1x.txt
Richard
post #6 of 23 Old 07-18-2007, 01:29 PM - Thread Starter
Carnivore's Avatar
Well yes I realize he has a whole list of things, some bigger than others, and some of which are the same as those found in the HDT-1. But the AM deemphasis tops the list for the 1X, and I can't figure out why that was changed from the HDT-1 as it seems like a step backwards.
Also as I mentioned in the "Initial Obeservations" thread, one of the first things I noticed was that the frequency response of analog FM sounded rolled off. Brian's FM deemphasis measurement seems to confirm that. Hmm, it seems that while the 1X added some nice new features, the actual tuner performance was better in the HDT-1 in several respects.
post #7 of 23 Old 07-18-2007, 04:29 PM
jr_tech's Avatar
Perhaps the departure from the NRSC deemphasis curve was made in a deliberate attempt to "brighten" the sound of 5Khz rolled-off AM transmissions?
jr
jr_tech is offline
post #8 of 23 Old 07-19-2007, 12:37 PM
jr
My feeling is that in making some of the changes they went back to scratch and missed that when they did so. I have still not gotten a clear response from the factory, but I expect one VERY soon.
post #9 of 23 Old 07-19-2007, 01:10 PM
bwam's Avatar
Quoted: 32 Post(s)
Since I'm in the market for an HD device (receiver or radio), why would I buy such a unit now with this difficiency?
bwam is online now
post #10 of 23 Old 07-19-2007, 02:44 PM
doxytuner's Avatar
Richard
When you look at all the problems listed by Brian, you begin to wonder if you want to purchase the Hdt-1X.
Richard
RicardoDurando likes this.
post #11 of 23 Old 07-19-2007, 02:54 PM
Richard
Um. . . . Or if I can get you all to put pressure on the factory for me! Go to the Sangean Taiwan website and e-mail them. Show the AVS forum force and get things done.
post #12 of 23 Old 07-19-2007, 05:18 PM
R.F. Burns's Avatar
I don't know. I'm not a piece of test equipment. Never have been and My other equipment is a Macintosh Ma-6100 amp/pre amp and Infinity Reference standard 2 speakers and all high end interconnects with monster cable speaker wire. It's a fairly good system and y'know what? I am really happy with the sound of my HDT-1X. I don't use it for AM unless I'm listening to a HD radio station. I also have a Sansui TU-717 tuner. The Sangean tuner sounds great to me. The radio is incredibly sensitive and selective in the very crowded N.E. US and with it I can hear stations I can not hear with any other tuner I've owned. The end.
R.F. Burns is offline
post #13 of 23 Old 07-20-2007, 06:27 AM
doxytuner's Avatar
Communicate Brian's complete report(2 parts) to the factory and they can make their own decision on improvements not only with regard to HD but other electronics.
Richard
post #14 of 23 Old 07-20-2007, 11:54 AM
Richard
I have already sent it to them. I will have a rundown of their response by the end of next week.
post #15 of 23 Old 07-26-2007, 04:05 AM
Sierra71's Avatar
Master Theseus,
Thank you for helping us with the Sangean radios. It's nice to have an insider's ear to bend about things!
I may be ordering an HDT1-x within the month, but I had a few questions about them...
Are there any issues or problem areas with the early-run HDT1-x units?
Does the remote operate on standard protocols? IE can a learning remote work with it?
Do you plan to release them in silver? (silly I know, but all my gear is silver...)
Thank you, Sierra
PS I still have a 1994ish RS branded Sangean SW portable, beat and abused, still works fine!
Sierra71 is offline
post #16 of 23 Old 07-26-2007, 10:22 AM
Originally Posted by Sierra71 View Post
Master Theseus,
Thank you, Sierra
The only known issues are the ones posted by Brian on his site. The major issue I see is the lack of NRSC? Deimphasis curve on AM analog. We are looking into this situation and all the other reports.
As for releasing in silver, that is not going to happen any time soon. The HDT-1X and HDT-1 will have to remain the only two models for a short while due to the work put into these models.
post #17 of 23 Old 08-07-2007, 07:14 AM
k6sti's Avatar
I have updated my HDT-1X review to cover version 0.3:
I have also updated my HDT-1 review to cover version 1.4F:
http://ham-radio.com/k6sti/hdt-1.htm
Brian
k6sti is offline
post #18 of 23 Old 08-07-2007, 12:24 PM
rwagoner's Avatar
Brian
What do these mean for the typical user?
>10. The AM varactor drive voltage no longer backsteps.
rwagoner is offline
post #19 of 23 Old 08-07-2007, 12:25 PM
rwagoner's Avatar
In other words, if I have an original HDT-1, is the upgrade a good thing or a bad thing? Outside of the clock and output level.
rwagoner is offline
post #20 of 23 Old 08-07-2007, 01:12 PM
k6sti's Avatar
I don't know that Sangean is offering an upgrade. I'm just reporting differences I found between firmware versions.
The varactor drive backstep was a minor bug without significant consequence.
The stepped muting and threshold differences are another matter. See the writeup for details.
Brian
k6sti is offline
post #21 of 23 Old 08-07-2007, 05:20 PM
rwagoner's Avatar
Brian
They will upgrade it to fix the clock and output level; the rest comes along for the ride. But it sounds like upgrading is not a good idea if the overall sound is not as good.
rwagoner is offline
post #22 of 23 Old 03-31-2008, 06:20 PM
Natural1's Avatar
I have recently become addicted to my local NPR Jazz station here in Atlanta and have really been enjoying the HD feed on my Marantz receiver. So, I've been thinking about adding another HD tuner to the bedroom system but I've been hesitant, looking for a good deal and not wanting to spend very much on the purchase. I happened to check newegg today and if any of you are interested in this particular tuner I highly suggest you go over there and check out the sale price, and shipping is free as well.
Hint: the in-cart price is lower than what it reports from the "click to see lowest price" link. I am a huge fan of newegg and have been doing business with them for about 6 years now, but be aware that this particular item is not refundable.
EDIT 4/1/08: Unfortunately it looks like the deal is over.
Natural1 is offline
post #23 of 23 Old 01-04-2013, 05:37 PM
baconti's Avatar
I have an HDT-1X and just learned of a reported problem with receiving FM stations that transmit an HD4 channel, not mentioned in the k6sti review. The HDT-1X has no problem receiving stations in the Boston metro area with HD1, HD2, and HD3 channels. However the HDT-1X refuses to lock on to 104.1 WBMX FM HD, apparently because it's confused by the additional HD4 channel that's transmitted by WBMX FM HD. I've since learned that the transmission spec was recently revised with additional digital bandwidth to accommodate HD4, something that my Sangean HDT-1X isn't able to handle. So I'm only able to receive WBMX FM analog with RDS display. As far as I can tell, no software upgrade for HD4 is available.
baconti is offline
Reply HD Radio
