96lbs. of Love! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 59 Old 04-18-2008, 02:06 PM - Thread Starter
04FLHRCI's Avatar
I wasn't expecting this guy until Monday; good thing I was home to provide a signature.
Bring on the Sicko!
Larry
04FLHRCI is offline
post #2 of 59 Old 04-18-2008, 02:08 PM
armystud0911's Avatar
hmm, I thought you were gonna post pics of some 5'1 blond that you took home last night.
armystud0911 is offline
post #3 of 59 Old 04-18-2008, 02:09 PM - Thread Starter
04FLHRCI's Avatar
Then I'd have to give up the A/V hobby and adopt a lawyer.
04FLHRCI is offline
post #4 of 59 Old 04-18-2008, 02:11 PM
sound dropouts's Avatar
dude, for a blond it is totally worth it
sound dropouts is offline
post #5 of 59 Old 04-18-2008, 02:26 PM
Looneybomber's Avatar
Liked: 25
Nice! Have you ordered replacement fans for it yet?
YID DIY
Looneybomber is offline
post #6 of 59 Old 04-18-2008, 02:27 PM
thylantyr's Avatar
Bring on the Sicko!
Larry
If you look at the QSC RMX4050 or 5050 back panel, there
is something there that is revealing & bugs me. I've told
people here and in pm.
A simple riddle, any takers?
Hint: Look at the back panel of this Face amp and compare
to the QSC.
The storm was gone, but dark clouds still hung around
The perfect setting for things to come......
thylantyr is offline
post #7 of 59 Old 04-18-2008, 02:50 PM - Thread Starter
04FLHRCI's Avatar
No Sir; I haven't looked into this yet - I'm certainly open to input thought.
Larry
04FLHRCI is offline
post #8 of 59 Old 04-18-2008, 02:56 PM
Bob7145's Avatar
Liked: 36
to the QSC.
Well the Qsc @ 1300w per channel =2600w on 10amps?
The Face has 15amp plug 1800w limit?
Face has input sensitivity switch?
Bob7145 is offline
post #9 of 59 Old 04-18-2008, 03:13 PM
cavu's Avatar
The specs on this thing are all over the map!
The owner's manual states the F2000TX produces 4200w into 4-ohms bridged with 30A of mains supply. (115V@30A=3450W input )
This amplifier is a Class A/B design which means its theoretical maximum efficiency is less that 78.5% ... therefore the maximum audio output power that can be generated with a 3450W power supply is something less than 2700W !!
In order to generate 4200W, the power supply would have to be a minimum of 5400W which is 115V@47A or 30A@180V. In fact, one table in the owner's manual states that the power requirement is 30A@200V !!!
The only way this could be produced with the existing setup would be to strap the power transformer for 220/240V operation which I doubt very much will meet UL/CSA safety standards.
This amplifier is obviously spec'd and intended for off-shore markets.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #10 of 59 Old 04-18-2008, 03:14 PM
AlexE's Avatar
/drool
AlexE is offline
post #11 of 59 Old 04-18-2008, 03:26 PM
thylantyr's Avatar
I like the hardwired power cord better on the FACE
Those cheap quick disconnects on the QSC gets a ->
I would probably mod the QSC
post #12 of 59 Old 04-18-2008, 03:39 PM
Bob7145's Avatar
Liked: 36
Yes, I do not like the detachable computer type plug either. I have a gaming computer that sometimes has problems with the heavy cord going into the power supply. Zzzzt zzzzzzzzt = check plug.
Bob7145 is offline
post #13 of 59 Old 04-18-2008, 03:44 PM
thylantyr's Avatar
Before you posted this, did you prepare yourself to get
yelled at for using your brain? I know that common sense
and reasoning can be contagious, but some people are
just against it.
I already pointed out inconsisent marketing data on their
other amp, in another thread, and got yelled at, in spite
that I'm just a messenger of the obvious.
Looking at Face audio marketing once more reveals another
erroneous specification across many of not all the amplifiers. [It has to be an typo because nobody would
design it that way, lol ]
I'll let this riddle float, akin to "Where's Waldo".
Not to beat the rotting dead horse, but what other
specification is not consistent between these two
documents?
http://www.faceaudio.com/pdf/TX.PDF
http://www.faceaudio.com/product2,4.html
post #14 of 59 Old 04-18-2008, 03:45 PM
cavu's Avatar
That isn't the BIG PROBLEM with the IEC power connector.
The BIG PROBLEM, as Bob7145 pointed out, is that the connector is limited to 15A. That's a total input power of 1725W which limits the amplifier audio output power to a theoretical maximum of about 1300W.
" - MLK
cavu is offline
post #15 of 59 Old 04-18-2008, 03:46 PM
thylantyr's Avatar
Give the beast a 30A circuit unless it voids warranty,
and should be ok, it has two fuses on the back panel.
post #16 of 59 Old 04-18-2008, 03:47 PM
thylantyr's Avatar
Relax... I'm in the same boat as you
There is ways to solve this.
post #17 of 59 Old 04-18-2008, 03:48 PM
cavu's Avatar
what other specification is not consistent between these two documents?
You wouldn't mean the delta of 28 pounds??
" - MLK
cavu is offline
post #18 of 59 Old 04-18-2008, 03:49 PM
thylantyr's Avatar
The bigger riddle is still open to analysis. Check it out,
it's not an easy find.
Hint: magnifying glass on the text
post #19 of 59 Old 04-18-2008, 03:59 PM
cavu's Avatar
Well, both documents tout a slew rate of 40V/millisecond. Must sound like a hydraulic cylinder. (They correct that in the owner's manual.)
" - MLK
cavu is offline
post #20 of 59 Old 04-18-2008, 04:02 PM
thylantyr's Avatar
Woot!
They have three different documents to describe the product and they need to correlate all three documents.
I know that is a tough job to do for a company that has been in business for 10 years.
post #21 of 59 Old 04-18-2008, 04:27 PM
cavu's Avatar
Woot!
Actually the slew rate was the very first thing I noticed when I scanned the specs but ignored it as it is an obvious typo ... I don't think they are deliberately conning the public by understating their slew rate by a factor of 1000!
" - MLK
cavu is offline
post #22 of 59 Old 04-18-2008, 04:30 PM
Bob7145's Avatar
Liked: 36
In my case it's the plug coming loose causing the Zzzzt zzzzzt.
Bob7145 is offline
post #23 of 59 Old 04-18-2008, 04:39 PM
thylantyr's Avatar
I'm not worried about the con game. We can analyze and figure things out. I'm just picking on the literature because
it's so easy to fix and I wouldn't be happy if it was my
company.
Some heads are gonna roll
post #24 of 59 Old 04-18-2008, 04:40 PM
thylantyr's Avatar
Fire up the amplifier........
post #25 of 59 Old 04-18-2008, 04:43 PM
TheEAR's Avatar
LOL
Thylantyr...this is some funny material !
I will get this amp regardless...if it clips at the levels I will use it...yes some heads will roll.
There are no pro amps that do not inflate numbers, none can maintain the max output for long and few can deliver on short bursts. Hey what do people expect a Krell MRA for under $3000?
Ask yourself mortal , do you have as much displacement as me ? The answer is no unless you have a Windmere fan sub.
TheEAR is offline
post #26 of 59 Old 04-18-2008, 04:49 PM
thylantyr's Avatar
What is the current market price for a Krell MRA ?
Using that price tag, what can you do to get similar results
by using other amplifiers ?
/hehehe
post #27 of 59 Old 04-18-2008, 05:47 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
"I already pointed out inconsisent marketing data on their other amp, in another thread, and got yelled at"
No one disputed Face's marketing discrepancies; you got yelled at for presenting said facts in a totally obnoxious way.
Noah
noah katz is online now
post #28 of 59 Old 04-18-2008, 05:55 PM
noah katz's Avatar
Quoted: 881 Post(s)
Liked: 304
"The BIG PROBLEM, as Bob7145 pointed out, is that the connector is limited to 15A. That's a total input power of 1725W which limits the amplifier audio output power to a theoretical maximum of about 1300W."
For the umpteenth time, who except meter jockies run amps w/continuous sine waves?
With program material's crest factor of 6 - 10 dB, clipping a 4000 W amp means the average power (which is what heats things) is 400 - 1000 W, and the effective capacity of 15 A electricals is 60 - 150 A.
Noah
post #29 of 59 Old 04-18-2008, 07:08 PM
Bob7145's Avatar
Liked: 36
Then why don't they advertise average power?
So my car suddenly has 2000 horsepower?
Bob7145 is offline
post #30 of 59 Old 04-18-2008, 07:26 PM
mgboy's Avatar
Um.. that's not nearly a good example, in fact it's horrid. Vehicles rated whp (at wheel horsepower, not at the crank) is rated at peak, not an average. If you were to rate car's horsepower how amps are generally rated, then they would seem to have much less horsepower.
mgboy is offline
