Some Shiva X designs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 04-21-2008, 01:56 AM - Thread Starter
armystud0911's Avatar
I did some designs for Kevin's Shiva X, hope you enjoy.
Some of these can be used for other 12" drivers if you want, but the mounting info and designs were done for the Shiva, you need to model other drivers to see if they work.
armystud0911 is offline
post #2 of 22 Old 04-21-2008, 01:56 AM - Thread Starter
Start off with the sealed ones
And a bigger sealed one
These are just the teasers, Kevin will have them on his site with full documentation pdf's and the actual sketchup files for download as well as cut sheets that work for ply and mdf
post #3 of 22 Old 04-21-2008, 01:57 AM - Thread Starter
Small ported designs...
Front Port
Rear Port
post #4 of 22 Old 04-21-2008, 01:57 AM - Thread Starter
Large Ported Designs
Front Port
Rear Port
Like I said, there are finished cut sheets for all these, also, keep your eyes peeled for much much more!
post #5 of 22 Old 04-21-2008, 04:31 AM
Hyperlite's Avatar
Sweet!! Thanks!
based on comparison with the recommended enclosures from exodus on the acoustic visions site, that small ported is an awesome box...17hz tune, on 500w you're getting 113db @ 20hz! in room, of course...but it models great, 3-4db down @ 17hz.
http://www.acoustic-visions.com/~aco...x/shivaapp.pdf
looking forward those cut sheets!
I'm thinking LT/550 just to keep costs down, what do you think army?
Hyperlite is offline
post #6 of 22 Old 04-22-2008, 06:31 PM
Hyperlite's Avatar
OK i got bored.
a little crude...and i couldn't get sketchup to render that port correctly on the front... anyway, that should be about 4.3ft^3 after bracing, etc.
post #7 of 22 Old 04-22-2008, 07:56 PM - Thread Starter
Good work, keep practicing, watch those tutorials and you'll get the hang of it.
post #8 of 22 Old 04-23-2008, 04:04 PM
Collo's Avatar
Nice work on those cut lists. Don't forget to factor in the width of the saw blade when cutting.
Drawing port flares in sketchup tutorial
Collo is offline
post #9 of 22 Old 04-23-2008, 05:43 PM
ba123's Avatar
With your testing what wattage does these drivers comfortably like and what is the largest you'd push them with? When modeling the sealed designs it seems like the sub reaches max excursion around 500 watts or so, but would you drive them with more?
ba123 is offline
post #10 of 22 Old 04-23-2008, 06:50 PM
Hyperlite's Avatar
Thanks! i thought about blade width at one point, but i figured since i wasn't really squeezing every cut i could out of the sheet i could slide by without that consideration for this one.
erm, i mean....you don't cut your MDF with a laser?!
And thanks a ton for the link!
ba123, 500w is good. You can always give them more, as long as your careful... but Pmax for the shiva is 600w.
post #11 of 22 Old 12-06-2008, 06:46 PM
jcroyle's Avatar
Has anyone built any of these subs?
I would like to build the 4.3 ported box. Any help?
Later
JimC
jcroyle is offline
post #12 of 22 Old 12-06-2008, 09:04 PM
mcjasonb's Avatar
Liked: 113
i got one in 3.3 sealed on 500 watts and its great for music, gaming, and most of the movies out there.
Nearfield rig: Laptop -> JDS Labs ODAC -> Emotiva Mini-X -> Pioneer SP-BS22-LR & SW8-mk2Headphone rig: laptop -> JDS Labs ODAC -> Emotiva Mini-X speaker taps -> modded AKG Q701H.T.: PS3 - Yamaha RX-V2500 - Infinity Alpha 50's - Alpha center - Harmon Kardon HKB6 rears, Epik SentinelMy last.fm profile
mcjasonb is offline
post #13 of 22 Old 03-17-2009, 08:33 PM
Fabricator's Avatar
Quoted: 71 Post(s)
Liked: 33
subscribing.
chasing rattles ......Pro8100 & Da-Lite HP 2.8 Cult member
Fabricator is offline
post #14 of 22 Old 03-24-2009, 10:49 AM
Cy-Gor's Avatar
it was mentioned there are cut lists for these, where might those be?
Cy-Gor is offline
post #15 of 22 Old 03-24-2009, 10:57 AM
dev_81's Avatar
Where are these cut sheets? Thanks,
Dev
Dev
Ashburn VA
dev_81 is offline
post #16 of 22 Old 03-24-2009, 12:12 PM
mjg100's Avatar
Dev
I sent you an email with the design and cut list for the 20" x 27" x 27".
mjg100 is offline
post #17 of 22 Old 03-25-2009, 10:42 AM
mlkmgr's Avatar
here is 6.35 cu ft. slot port design tuned to 18Hz
and the cut sheet. ***You must purchase a cutsheet that measures .75X49X97. i found them at lowes in my area. ***
mlkmgr is offline
post #18 of 22 Old 03-25-2009, 11:54 AM
Cy-Gor's Avatar
Perfect, now all i need to know is if the shiva-x will work ok with the NHT SA-2 amp i have currently.
as a side note, did you avoid doubling up the baffle to keep it to one sheet of MDF?
Cy-Gor is offline
post #19 of 22 Old 03-25-2009, 04:42 PM
mlkmgr's Avatar
yeah, i had asked at another forum and they stated only one sheet of mdf would be sufficient. and yes, it helped keep me to one sheet of mdf
as far as the amp, i don't know. i went with the parts express 500W plate amp. something about a sub-sonic filter being needed or used or something. i am not sure of the exact details of this, but if you ask i am sure someone can help out.
mlkmgr is offline
post #20 of 22 Old 03-26-2009, 08:08 AM
dev_81's Avatar
Is the above slot port design better then Large Ported Designs (with two flared ports) in terms of sound quality for music and HT? I mean which one is better? What are pros and corns?
Dev
Dev
Ashburn VA
dev_81 is offline
post #21 of 22 Old 03-26-2009, 04:14 PM
mlkmgr's Avatar
i couldn't tell you which is better, but by having the slot port, you don't have to purchase the additional ports or cut pvc pipe to the correct length.
for me, the advantage was cost. if you look at the shiva pdf's on the diy website, you see they use 2 "precision ports" at a cost of $19 each. factor in the additional shipping cost and you are looking at close to an additional $50 for your build.
mlkmgr is offline
post #22 of 22 Old 03-26-2009, 07:55 PM
dev_81's Avatar
Thanks, so I think slot port design looks easy to construct, compare to flare ported. i will go with slot ported sub.
Which of the below amps I should go with for above slot port design & why:-
1) http://www.parts-express.com/pe/psho...number=300-752
2) http://www.parts-express.com/pe/show...number=300-806
Dev
Dev
Ashburn VA
dev_81 is offline
