Nested Sonotube tapped horn? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 06-23-2008, 03:07 AM - Thread Starter
ChrisBee's Avatar
I thought I'd share a rough drawing of something which might work and avoid all that woodworking.
Skirt clearance from the floor is obviously a variable depending on the mouth area required.
Scale it to taste, size and response requirements.
The design can easily be inverted and the top left open though with much higher center of gravity.
Further tubes can achieve very long horns if required.
Tapering to match theoretical flare requirements is probably unecessary in real life.
Thoughts?
ChrisBee is offline
post #2 of 45 Old 06-23-2008, 12:07 PM
AlexE's Avatar
That's not really a horn but an aperiodic vent, or a stab in the dark at a trasnmission line. You're talking about nesting a skinny sono in a fatter sono, right?
AlexE is offline
post #3 of 45 Old 06-23-2008, 01:39 PM - Thread Starter
ChrisBee's Avatar
The old Tricolumn design used nested parallel-sided tubes to achieve a workable 1/4 wave folded horn.
This is a similar idea but using a simplified tapped horn layout instead.
It's not a transmission line because the driver is at the throat and the mouth of the horn simultaniously. (just like a tapped horn)
It may require some scaling or adjustment of the relative positioning of the driver to the throat and mouth.
Ignore the lack of taper and it looks much like the enthusiast built examples of tapped horn enclosure. (Google image search)
Here's the driver "moved" further away from the horn throat: Take your pick: Scale as necessary.
ChrisBee is offline
post #4 of 45 Old 06-23-2008, 08:48 PM
AlexE's Avatar
IMHO that would sound like s%%t, but what do i know. I had some old motorolla speakers that had something like that going on, you know, back before people understood sound. What is all this going to achieve? Are you tuning the whole apparatus like a regular port for flatter response, or just have some acrylic sonotubes and want the pimp factor? I swear I'm not throwing hate, I'm just confused.
AlexE is offline
post #5 of 45 Old 06-23-2008, 08:58 PM
zamboniman's Avatar
problem is there is no horn here tapped or not
zamboniman is offline
post #6 of 45 Old 06-23-2008, 10:59 PM - Thread Starter
ChrisBee's Avatar
Then you are not obviously familiar with the Tricolumn folded horn? Or the Paraline?
Here's the Tricolumn: The same nested, parallel-sided tubes but in a different layout.
Can't you see the family resemblance?
I'm not drawing a Paraline. Nor a KEF B139 endowed Bassett coffin!
ChrisBee is offline
post #7 of 45 Old 06-24-2008, 01:32 AM
2100's Avatar
You could build it, and then see if it really can do sensitivity of ard 100dB (or any appreciable gain against a vented box) for 1W. Or pump 100W into it and measure at 10m, GP. Then match the cu vol of yours against the appropriate model in the Danley line.
2100 is offline
post #8 of 45 Old 06-24-2008, 09:31 AM
zamboniman's Avatar
Surely... I have very little knowledge of both.. but I do have a decent grasp on the physics of speaker and enclosure design..... And what you have pictured offers up very little if any "horn".... crude at most and if any benefit gained is most likely not due to the properties of horn loading.
post #9 of 45 Old 06-24-2008, 10:15 AM
Mark Seaton's Avatar
Quoted: 651 Post(s)
Liked: 1754
Actually this approach does work. There will be affects at higher frequencies that depend on the cross section of the internal area at the bends, but below 100Hz you can have a response that is akin to a horn.
Tom Danley himself had planned out some conventional horns and tapped horn designs using nested tubes, although I don't recall any of those coming to life recently. He did always note that long ago he built a BIG transmission line subwoofer in exactly this manner.
In operational terms, Tom liked to describe the straight segment approach as "digitizing the horn." The average area vs. length and total volume define the horn's operation, and the number of segments or steps needed is just a question of the upper bandwidth needed and the areas involved.
Mark Seaton
Seaton Sound, Inc.
"Make no little plans; they have no magic to stir men's blood..." Daniel H. Burnham
Mark Seaton is online now
post #10 of 45 Old 06-24-2008, 11:16 AM
zamboniman's Avatar
Wonderful... funny how everytime I open my mouth... MS isn't too far behind to kick me in the head.
Mark once again thanks for a tiny crumb (no matter how small) of your insight and knowledge base.
Now time to crawl back into the hole... maybe go clean some ice... I think I should stick to RF
post #11 of 45 Old 06-24-2008, 11:36 AM - Thread Starter
ChrisBee's Avatar
Thankyou, Mark.
There were some coloration issues with my 7 feet x 18" diameter steel drum, bass Tricolumn.
ChrisBee is offline
post #12 of 45 Old 06-24-2008, 02:56 PM
AlexE's Avatar
So Chris can pick up where Danley left off. I'll stand by for pics and plots Or at least an explanation of why danley said "F%%k it" to these designs after some pot inspired back yard experimentation....
AlexE is offline
post #13 of 45 Old 06-24-2008, 05:06 PM
2100's Avatar
A big tube looks fugly in the pro audio world, can't stack/array? But perhaps something that's no good for us also, like it doesn't sound good esp when its pushed....bad freq response, not enough gain over appreciable BW so its not too far off from a vented sub of equal vol etc. Never know till you've built it and listened critically. There are many horn subs in the market, but from what one can read...some sound better than others.
2100 is offline
post #14 of 45 Old 06-24-2008, 11:54 PM - Thread Starter
ChrisBee's Avatar
AlexE
Critics are two a penny these days.That's a priceless luxury you earned off our early experiments and efforts at our own expense. If you don't like an idea then just ignore it or do a proper anlaysis. Or throw one together just to prove how awful it is. Then you've earned the right to trash an idea which you clearly don't even understand at the most basic level. You had the drawing but you still needed single syllable decriptions to grasp the concept?
I don't need to build to prove anything. My Tricolumn days were back in the late 60s when every single Watt and Hz of extension was precious. Subwoofers in 1968/9 were as rare as hen's teeth. No longthrow Chinese drivers at pocket money prices either. No sonotubes. No free software test facilities or cheap SPL meters. (thankyou Sir JohnM) No Behringer EP2500 1kW amps for less than a week's wages for a factory worker. No routers or other affordable electric tools to produce a sub in a weekend. No internet to share potential ideas freely with your audio friends right across the globe without expectation of payment or reward or sympathy. (just simple respect) There was no easily affordable SVS Ultra to fall back on as your reference for what is acceptable or probably inadequate.
My big Tricolumn sub was made out of a stack of big, empty, steel drums. Which all had to have the tops and bottoms cut out with a hammer and wood chisel on the kitchen floor of our flat/apartment. (with the door shut!) Then all taped together to make a big tube. The speaker cutout was made with a keyhole saw handle with a stub of hacksaw blade jutting out. Smaller holes were made with a hand drill and blunt, carbon steel drills. (Which quickly burnt out in the single high speed B&D electric drills of those days) The speaker cable was twin clear lighting flex from the 10 watt Mullard 510 mono, valve, power amp. The driver was a 10" Whitely cambric reinforced paper cone and corrugated surround. Xmax was probably a millimeter or two but I hadn't heard of TS parameters in my borrowed reference (library) books or "Wireless World" back then.
There wasn't much snake oil to discolour your wads of spare pound notes or dollar bills back in the "Good Old Days". Just enthusiasm, inspiration, aching arms, blistered fingers and sticking plasters. When you can claim to have carried 112lbs of damp sand (for a reflex corner baffle experiment) 13 miles home from the nearest wharf on a bicycle...then baked every precious spoonful on your wife's cooker to dry it out before use ... then you're an audio enthusiast and have probably paid your dues. You don't need to prove anything to anybody. Least of all to a forum "expert" with (apparently) no manners and a remarkably poor grasp of potential enclosure designs.
Have a nice day.
ChrisBee is offline
post #15 of 45 Old 06-25-2008, 02:20 AM
Collo's Avatar
I tried nesting tubes to make a concentric port.
Even went as far as to publish a calculator for tube sizes and endgaps.
I found that there was too much turbulence when the air had to change direction. Fun though...
Collo is offline
post #16 of 45 Old 06-25-2008, 02:47 AM - Thread Starter
ChrisBee's Avatar
Hi Collo
That's excellent information! Exactly as we have come to expect from you as a continuingly useful resource for builders.
Ports have a much higher velocity and are inherently rather small in comparison with simple, tubular folded horns. (tapped or otherwise) That is not to say that the pipes involved won't have their own "out of band" resonant frequencies. Perhaps the BFD is our answer to such colorations? I ran my Tricolumn fullrange so had to make do with its vices. It sounded wonderful on violin concertos. Like warm, red wine. These days with 3rd order digital crossovers everywhere and a BFD these old designs could be the replacement for the LLT.
ChrisBee is offline
post #17 of 45 Old 06-25-2008, 03:05 AM
AlexE's Avatar
AlexE
Have a nice day.
So instead of explaining how your wonder tube works you call me dirty names and tell tales of a cut up trashcan and baking sand one spoon at a time back in the late sixties. I think you're insane, yes, even if we have it easy "these days" Good luck though. I don't have to build or prove anything any more than you do by the way
AlexE is offline
post #18 of 45 Old 06-25-2008, 03:28 AM
AlexE's Avatar
In fact let's take a look:
All that woodworking? Seems trivial to build a box for someone who rides a bike for 12 miles with 100 pounds of beach sand. Regardless, if that's the only 'advantage' there is then I can see why Danley didn't want any of it.
Thoughts?
Oh man, order yours today, right? I'm sure it will "probably" sound okay.
Seriously, dude, you asked for thoughts, I gave some to you. Sure it looks like it ruffled your feathers, but you still haven't given an ounce of physics behind your concept other than mentioning that it's a horn system. Well great, hey, I invented a horn too. It does a million dB with one watt. Driver, dimensions and all? Oh, well uh obviously it can be scaled to fit. Yeah, just scale it to fit... It works by... you know, horn principles.
AlexE is offline
post #19 of 45 Old 06-25-2008, 04:22 AM - Thread Starter
ChrisBee's Avatar
My suggestion for "reverse engineered, alien technology" as an alternative to existing subwoofer box designs has obviously left you flummoxed.
ChrisBee is offline
post #20 of 45 Old 06-25-2008, 07:44 AM
2100's Avatar
One big difficulty I see here is to get the right driver to fit the sonotubes after modelling (is there any horn sim software for the tubes anyway...), which i believe the tubes comes in fixed sizes/dia?
2100 is offline
post #21 of 45 Old 06-25-2008, 08:36 AM
bossobass's Avatar
Quoted: 78 Post(s)
Liked: 668
AlexE
Have a nice day.
Interesting story. It brought back many memories and one I thought I should relate:
33 years ago, I got the idea to build 3-way speakers that had a separate woofer box, in which was contained the crossover and a 12" woofer in a ported box of 3 cubes, a separate 6" midrange cube and another separate (and pretty cool looking, slim box, if I say so myself) with 2 tweeters.
The mid and tweet boxes wired off the back terminals of the woofer box from the crossover and could be placed for maximum sound stage in any room.
I used sink cutouts from our counter top shop to build the woofer box, which already had laminate on one side, which I turned to the inside of the box. I then laminated the boxes with wood grain laminate.
Although I co-owned a kitchen/bath company and had access to table saws, routers and saber saws, I used fairly rudimentary tools and built them at home in my spare time. I based the design on ideas gathered and sifted from the book 'Hi Fi Loudspeakers and Enclosures' published in 1947 (IIRC). It had all of the theory for horns, ported, drone-cone inverters, folded horns, sealed, infinite baffle, etc., and had designs from Bozak, Klipsch, Jensen, Altec, Lansing (JBL was signed Jimmy B Lansing on the back of the box of one of them), University, Wharfdale, etc.
I built a couple dozen sets and sold them back in 1975-76, allowing the purchasers to select their own wood grain. I fondly remember my wife and I, newly married, in a tiny apartment with saw dust up to our ankles in the living room from me routing the laminate trim, while she soldered all of the connections.
I recently was contacted by one of the purchasers who told me that his basement was recently flooded in a storm and his speakers were destroyed. He asked if I would build him another set like he had. I explained that technology has made leaps forward and that it would be more economical and offer more design choices to just buy a pair from any number of manufacturers.
He asked if I would draw plans for the speakers so that he might try to build a set himself because he wanted those speakers in that design. He used them in his shop and placed the woofers in niches and had built shelves for the mids and tweeters so that the sound was good anywhere in his shop (according to him).
Well, I decided to rummage through my attic and sure enough, I found an old set that I had used myself and saved (I save EVERYTHING).
I decided to blow off the dust and ship them to this guy so that they'd have a home and he'd be happy to get what he wanted, free of charge.
In the process, I noticed and remembered the hand wound coils in the crossovers that we made ourselves with a drill, spool and wire, as well as the clever little things I would write inside the boxes for posterity I calculated the box size and port with a slide rule because I couldn't afford the exorbitant price of a calculator when they first came available, etc.
We hooked them up and measured them. Since the components are separate, they were easy enough to measure separately and then as a whole.
I must say how stunned I was to see the accuracy of the overall FR as well as the slopes and points of the crossover. The ported box was flat to 28Hz and they had a slightly rising response from 10K to 20K. In fact, I am amazed that the rubber surround (a rarity 35 years ago vs cheap foam or corrugated, impregnated accordion-type surrounds) of the woofers was still intact and that everything was in near-perfect working order.
The speakers were delivered last Saturday to a very grateful guy who will have them until the next natural cause of their demise, which is pretty cool to me.
I bought the drivers from a high school friend who was a stateside distributor for Phillips. He went on to have many amazing experiences in pro sound, including a long meeting with Paul Klipsch who explained to him that those old timers had discovered, discussed and written about things like digital, fiber optics and solid state in the late 40s, and then proceeded to prove it by pulling articles from his vast library, which was adjacent to his office.
Sorry for the ramblings, and apologies to the youngsters who are somehow put off by these sorts of stories, but I wanted you to know that I always enjoy the old war stories like yours. I appreciate your input, even though I'm not up on horns and other larger solutions like PK, et al.
Please continue...
Bosso
bossobass is offline
post #22 of 45 Old 06-25-2008, 09:17 AM
Quoted: 651 Post(s)
Liked: 1754
Actually, I know for a fact that Tom designed and built an experimental avalanche control device using stepped pipe segments of increasing size. This wasn't a music reproducer and operated mostly in sine wave mode, but it was light and efficient for the huge package size that sat on a flat-bed trailer pulled by a semi. That device actually ran off a gas powered motor turning a crank to drive the horn at 12Hz which I'm told was enough to make the leaves on surrounding trees quiver.
Ironically, Tom often suggested and wanted to build a horn out of the nested pipes as he appreciated the elegance and economy of the implementation, but generally the package wasn't conducive to the application, market desires, or those who would ultimately produce the final speaker. One of the wacky designs that led to the Tapped Horn (actually one of the first tapped horn designs), was conceived and designed to use pipe segments, but the potential client's project was delayed or sidetracked for reasons not related to the acoustic device. Yes, this was a wider range device using more conventional drivers and some of the designs I am referring to were intended for pro or home audio.
As I explained above to those who actually read through the response, pipe segments work just fine so long as you understand and reasonably account for the limitations. The hurdles are very similar to those encountered in folding a horn. Come to think of it, a handful of the tapped horns which have been built as well as those Danley Sound Labs sells do in fact use some straight profile segments. So long as you account for whatever changes that imparts on the behavior, it can function just fine, and sometimes it even works better for the use. Whether the straight segment has a rectangular or circular cross section is of minor consequence until higher frequencies, with both having benefits depending on the use and dimensions involved.
Mark Seaton
Seaton Sound, Inc.
post #23 of 45 Old 06-25-2008, 09:30 AM
Quoted: 651 Post(s)
Liked: 1754
I would have to check, but I recall finding almost exactly this design patented or simply branded by one of the computer speaker companies, likely Creative or Logitech. Their embodiments are usually molded plastic which affords some added flexibility in the 180 deg bending. A port and a horn have some similarities, but also some important differences. At the 1/4 wavelength loading point, you generally have simultaneous low velocity with high pressure at the throat, while having high velocity and large air displacement at the mouth. Obviously this will have different requirements for the pressure coupling/quarter-wave resonance than is present in a port where we are concerned with smooth air-flow and end termination to reduce air flow noise. How the bends and turns are handled becomes critical, as any expansion and contraction of area inside the port would be very detrimental to air flow.
While not the same, a look at Polk's Power Port design is another interesting twist. Way back when he designed it, Mathew Polk actually posted a spreadsheet to calculate such a port for DIYers. Not a bad idea, but hard for most to build efficiently without custom molding/tooling or owning a lathe.
Much of my own work in the past few years has involved going back to good ideas which we weren't able to implement correctly at the time, or didn't understand all of the variables at work. Bandpass subwoofers and horns are but two easy examples.
Mark Seaton
Seaton Sound, Inc.
post #24 of 45 Old 06-25-2008, 09:47 AM - Thread Starter
ChrisBee's Avatar
Great stuff, gentlemen.
Around about now one of is supposed to say "Kids today? They don't know they're born."
I've done coil winding in the lathe in back gear. DCC: Double cotton covered copper wire nearly an 1/8" in diameter. Still have some of my early coils somewhere. Ugly as sin.
Our generation invented teenagers (and rock music) but you never get any thanks. They should have refused the patent!
ChrisBee is offline
post #25 of 45 Old 06-25-2008, 09:53 AM
Willd's Avatar
Great story Bosso!
Willd is offline
post #26 of 45 Old 06-25-2008, 11:18 AM
AlexE's Avatar
Chris, all we've learned here is that this design was used by someone as a non-musical device, I'm young, you're crazy and that's about it. At least you're blowing steam off by pulling the age card. Better in my opinion than just flat out calling me rude to defend your thread and whatever else is on the line in your mind
As for long winded stories about the good old days, they are fine - I for one come here to read, learn and get up to snuff on all sorts of oddball ideas like this one for instance. It's a bit out of place when someone asks for the magic behind the claims though. Surely a good follow up to a good explanation, but more of a side dish. FIY I've read all of it, Marks posts, Bosso's, all of it. Meybe if Chris posted here more than 7 times per year he'd understand I'm not here to flame anyone - just to learn. Hard to learn anything when we go off talking about the late 60s and bicycles in a thread about a bass horn though =]
AlexE is offline
post #27 of 45 Old 06-25-2008, 01:00 PM - Thread Starter
ChrisBee's Avatar
Maybe if Chris posted here more than 7 times per year he'd understand I'm not here to flame anyone - just to learn.
Ah but, Grasshopper.To learn you must be still and quiet. Open to all potential sources of information. You do not yet have the skills or knowledge to know what is useful to you and what is not. Yet still you judge. Governments invest billions in defense contracts on whims and fantasies whch never become reality. Basing their hopes of success only on their expert advisor's opinions. Do you think you have the skills to do better when only a simple cardboard tube and an hour's work is at stake? You could build and test one in less than an hour. I know I could. Yet you hesitate. You have already wasted more than an hour of your alloted time on this earth in idle chat with someone whose ideas you do not remotely respect. Time accelerates with each breath you take. This is a indisputable fact. Use each breath wisely and the burden of disappointment with your lack of achievements will not be too much to bear. (when it is far, far, too late)
ChrisBee is offline
post #28 of 45 Old 06-25-2008, 01:57 PM
Ricci's Avatar
Quoted: 245 Post(s)
Liked: 573
So far this is an interesting thread. I'm enjoying the stories from Bosso, and Chrisbee. Collo is throwing out some interesting port designs and Mark is discussing the powerport and the plausibility of this nested horn idea. I'm enjoying all of it.
AlexE,
Chill man. Maybe if you quit attacking Chrisbee we will get down to the underlieing principles that may or may not make this nested horn suitable for a subwoofer system. Just because someone only has a few posts does not mean that they are a newb or some kind of audio moron.
Ricci is offline
post #29 of 45 Old 06-25-2008, 02:33 PM
AlexE's Avatar
Wow Chris.
There is a lot of effort on your part to discredit me, and yet nothing at all about sizes, proportions, or much at all about the nestled sonos. Would it kill you to say something like "the backwave reiforces the sound pressure like a ported design, but the stepped diameters provide a horn system at the mouth?" The S in AVS stands for science, not s%&t talk.
You made a thread where you present an unusual design in order to "avoid all that woodworking" and resort to calling the nonbelievers all sorts of things and start talking about goverment investments. I get it, Chris.
I'm seriously cracking up over here. ESPECIALLY at your feeble attemtps to argue ad hominem.
http://en.wikipedia.org/wiki/Ad_hominem
Read it and weep buddy, my age has nothing to do with an abstract idea that you refuse to explain yet so feverishly defend against all questioning.
"Guys i have a bass horn design! Just scale it to fit, it's better than ported cabs. Trust me here, I made one out of a trash can in the late 60s. No, don't ask what sizes anything should be, or in what proportion. Tapering is probably not needed. You youngsters wouldn't understand! Rude Grasshoppers can't learn by asking."
Laughter really is the best medicine. That's your posts in a nutshell. I feel much better! Thanks.
Honestly speaking, this thread would have gone down the toilet if I didn't say what I thought and drew attention to it. I think I'll leave it alone now, and let this thread sink to it's proper home. When even Mark S. can't come up with some solid guidelines for such a design, I doubt many others will have anything to add. You personally got squat other than that MSPaint drawing. Most new poeple here looking to build a working sub will have the brains to stay away from shot-in-the-dark designs, so no harm done - carry on with the BS...
-Alex
AlexE is offline
post #30 of 45 Old 06-25-2008, 02:37 PM
AlexE's Avatar
AlexE,
I'd like nothing more than information from this man. Post count has nothing to do with it. I doubt we'll get to understanding any principles, as there are none. When even Mark S. can't come up with any proper guidelines for such a design, I doubt many others will have a lot to add. Chris seems lost in his own thoughts too
AlexE is offline
