How to wire plate amp to driver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-30-2008, 01:30 AM - Thread Starter
Aaron909's Avatar
How's it going guys. I'm almost ready to go out and start my Tempest-X 15" subwoofer build. I'm gonna go with a sealed 7 cubic foot box.
Could anyone please provide me with a diagram or explain to me how to wire the entire thing? Will I need any special tools like a soldering gun, or any special kind of connectors? The driver I'm gonna use is a Tempest-X 15" subwoofer, and a 500W O-Audio Plate Amp. Thanks in advance.
Aaron909 is offline
post #2 of 14 Old 07-30-2008, 11:52 AM
Jerm357's Avatar
The Tempest X product sheet has some diagrams that show how to wire the driver, You will just want the end result to be a 4ohm load so I would do the first one on page 5.
http://www.diycable.com/main/pdf/Tempest-X.pdf
Heres some other links that show how to wire all types of drivers and amps.
http://www.crutchfield.com/S-6WqyO53...=DVC2x2&subs=2
Jerm357 is offline
post #3 of 14 Old 07-30-2008, 02:25 PM - Thread Starter
Aaron909's Avatar
Thanks, I actually looked at both those links before deciding on my own thread. But looking at the picture below, on the left side, theirs 2 positive wires, and 2 negative...do I have to solder them together? Maybe I need to see a close up of one side of the subwoofer driver. Thanks
Aaron909 is offline
post #4 of 14 Old 07-30-2008, 03:49 PM - Thread Starter
Aaron909's Avatar
Sorry for the double post
Here's a diagram I drew up showing my confusion...was also wondering if anyone knows if the O Audio 500w plate amp comes with ends already attached to the amp like in my drawing? If not what kinds of wires will I need.
Aaron909 is offline
post #5 of 14 Old 07-30-2008, 08:11 PM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
Take the red wire from the amp and connect it to the positive (red) terminal on the sub. Take the black wire and connect it to the negative (black) terminal on the sub. You can connect the amp to either pair of terminal but not both. The amp comes with wire but you may need to add more depending on your enclosure. The sub comes with spring loaded terminals. Connecting the wires is as easy as pressing the terminal down, inserting the wire in the hole and releasing the terminal. The most difficult part of the process will be stripping about 1/2" of insulation from the ends of the wire. You can use a wire stripper, scissors, steak knife or even pull the insulation off with your teeth. Not that difficult.
-Robert
rlj5242 is offline
post #6 of 14 Old 07-30-2008, 08:19 PM - Thread Starter
Aaron909's Avatar
Thanks alot, for some reason I thought both pairs of terminals on the subwoofer had to be connected. Could you tell me why this picture shows both pairs used?
Aaron909 is offline
post #7 of 14 Old 07-30-2008, 09:48 PM
Brian Hinther's Avatar
Hi, Aaron. You've basically got it right. Since the Tempest-X has two 8 ohm voice coils, you need to wire them together (in parallel--red to red, and black to black) to knock the impedance down to 4 ohms for the O-Audio plate amp.
No, you don't need to solder the speaker terminals. When you push the connectors in, they expose a rather large hole into which you can insert your wire. With the holes being that big, I'd be tempted to go with 12 gauge speaker wire from Lowe's or HD for 50 cents a foot, IIRC.
The amp is expecting you to use spade lugs to hook up to its fiendishly hidden connectors. You could solder the lugs to the wires if you wanted to and then hook them up. You could probably find a pair already made up, too, if you didn't want to bother.
Then you run the bare end of the "+" wire over to one red speaker terminal (which is already hooked to the other red terminal, per your diagram) and the "-" wire to the other terminal(s) and you're done!
Thanks for making me take a closer look at my components to make sure I wasn't lying to you. And good luck with your build. I'm still a few weeks off from getting my workshop organized and new sawhorse built, but I can hardly wait!
Brian Hinther is offline
post #8 of 14 Old 07-30-2008, 11:11 PM - Thread Starter
Aaron909's Avatar
Ah okay I think I'm getting it now.So one of the pairs of terminals will have 4 ends connected to it? I never knew that was possible. I'm going to look for cable that has lugs attached to the ends of it.
So this is the way it's supposed to look right?
Aaron909 is offline
post #9 of 14 Old 07-31-2008, 06:10 AM
rlj5242's Avatar
Quoted: 48 Post(s)
Liked: 40
Don't. All you need is bare wire. In the one set of terminals that have 2 wires each, you just twist the wires together and insert them in the terminal hole.
100% correct.
-Robert
rlj5242 is offline
post #10 of 14 Old 07-31-2008, 09:52 AM
LTD02's Avatar
Quoted: 2340 Post(s)
Liked: 2571
i had this same question when i read the wire diagram last year. aaron's artwork definitely is more clear. nice work aaron!
Listen. It's All Good.
LTD02 is online now
post #11 of 14 Old 07-31-2008, 01:06 PM - Thread Starter
Aaron909's Avatar
100% correct.
-Robert
Thanks so much everyone, really appreciate it.
rlj5242, do you know if the amp comes with wires already, because I'm checking out the manual for it and on page 9 it shows just the "+" and "-" terminal but no wires comin out to plug into the driver.
Aaron909 is offline
post #12 of 14 Old 07-31-2008, 07:32 PM
Getting closer. On the Tempest-X, each of the four terminals will have 1 wire connected to it. That the would be the wire connecting the positives and negatives to each other.
Two of those terminals (one + and one -) will also have another wire connected to them from the plate amp. That will make two wires in each of those terminals, and they can easily be twisted together as mentioned above. The holes in the terminals are so big you'll have no trouble at all.
It's the other end of that wire that I'm worried about, the end that connects to the amp. The spade lugs there are nowhere near as accessible as in Aaron's drawing--I wish they were. The O-Audio manual also makes them look like they're out in the open, but on my amp, at least, the wiring in front of them makes it really difficult for fat fingers like mine to get on them. And the holes in them are very small--maybe 22 gauge wire size?
That's the end that IMO needs spade lugs, which wouldn't be that difficult to push on. That's why I'd rather mess with those wires (putting spade connectors on the end of them) out in the open where you can get at them, and them push them onto the lugs on the amp. But YMMV.
post #13 of 14 Old 08-01-2008, 02:48 AM - Thread Starter
Aaron909's Avatar
Thanks Brian.
I've got a feeling that I'm over thinking this. Hopefully when the amp arrives in about 1 week that it's as easy as the pic below:
I'm hoping the amp comes with wires (black & red) already attached to it like in the picture, but telling from the manual...it doesn't look like that is the case. One of the reasons for all this is because I don't want to have everything ready to build and discover at the last minute I need to make a trip to the hardware store.
Aaron909 is offline
post #14 of 14 Old 08-01-2008, 07:59 PM
You know that old expression about wishes and fishes? I can tell you for a fact that the only wire that came with my amp was a power cord. You might want to at least locate a nice pair of speaker cables with spade lug connectors as shown, in case yours arrives the same way.
