Thinking of porting my sealed enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-14-2008, 02:06 PM - Thread Starter
agulha's Avatar
So I have a sealed enclosure, about 2" cube, for my SDX15 with a BASH500 amp. I'm realizing I could use a little more SPL, plus finding my amp is overheating too much, so Im thinking really seriously about porting the enclosure. My one concern is that the geometry of the enclosure is close to a cube, which I have heard can be problematic for resonances with a ported box. Any thoughts on this?
I suppose if it sounds terrible, I can re-seal it.
Would love to hear your ideas/opinions.
agulha is offline
post #2 of 10 Old 08-14-2008, 02:24 PM
NEO Dan's Avatar
Go passive radiator
Dan
NEO Dan is offline
post #3 of 10 Old 08-14-2008, 02:28 PM - Thread Starter
agulha's Avatar
why passive radiator? less resonance problems?
I might not be able to because of all the bracing. But there might be a way.
agulha is offline
post #4 of 10 Old 08-14-2008, 03:16 PM
mgboy's Avatar
About two inches cubed? two cubic inches?
=X
But really, is that two cubed feet or 2ft*2ft*2ft? The former is too small to port effectively.
mgboy is offline
post #5 of 10 Old 08-14-2008, 03:26 PM - Thread Starter
agulha's Avatar
yes i stuffed a 15" driver in a 2" cubed box =) Had to break some laws of physics, but its quite compact...
(i think this is called a spinal tap moment.)
no really its about 2'x2'x2'. I think it worked out to around 190L.
Sorry about the confusion
agulha is offline
post #6 of 10 Old 08-14-2008, 03:41 PM
mgboy's Avatar
Haha, I figured - just being silly and pointing out a typo. It's all good. Well in that enclosure if you did want to port it, I'd use a 6" port, about 29 inches long. That results in about a 17-19 Hz tune depending on the volume taken by the driver, port, and any bracing.
mgboy is offline
post #7 of 10 Old 08-14-2008, 03:53 PM - Thread Starter
agulha's Avatar
what about 2 ports? say 4" diam each? Im not sure I can fit 6" tubing between the holes in the bracing.
agulha is offline
post #8 of 10 Old 08-14-2008, 05:02 PM
mgboy's Avatar
Well, two four in. ports at 28 inches each would work too, but you have less cross section, therefore more chuffing and what not.
mgboy is offline
post #9 of 10 Old 08-14-2008, 07:53 PM
penngray's Avatar
Liked: 43
Extend the tub out of the box, kind of like what the HSU Turbo designs do.
penngray is offline
post #10 of 10 Old 08-18-2008, 02:54 PM - Thread Starter
agulha's Avatar
cool i was just thinking about that.. so there is no reason the port tubes need to be _inside_ an enclosure right??
thanks
agulha is offline
