Behringer EP2500 How to use - for a novice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 123 Old 08-29-2008, 08:09 AM - Thread Starter
E-A-G-L-E-S's Avatar
In my research I have realized that the information for this commonly used amp is all over the place.
I thought, perhaps niavely, that the experienced guys could fill this thread with the common connections/set-ups for this amp.
Discussing any mods that are commonly done, like the fan mods, filters, etc.
A novice/beginner can be easily overcome by all the information and not be able to make heads or tails of it.
Perhaps this thread can be a sort of FAQ or User Guide. One can include parts names and possibly where to find them.
Seems as though most here would love to see people jump in the DIY ring, but I can tell you experienced guys that it is daunting and something like this could really help!
Thanks to anyone in advance who is so kind as to offer their help and knowledge on this amp.
E-A-G-L-E-S is offline
post #2 of 123 Old 08-29-2008, 09:14 AM
mynym's Avatar
Quoted: 31 Post(s)
DIP Switch Configuration for EP2500 set up for bridged mono mode
1 - Right
2 - Left
3 - Right
4 - Left
5 - Left
6 - Right
7 - Right
8 - Right
9 - Left
10 - Left (It mentions: "Switch off the input 2 clip limiter and filter" in bridge mode on back of amp in top left corner)
Also make sure the Input 2 attenuator is turned down completely.
mynym is offline
post #3 of 123 Old 08-29-2008, 10:22 AM - Thread Starter
post #4 of 123 Old 08-29-2008, 10:26 AM
XanderMoser's Avatar
To connect the LFE output of a receiver to a pro amp, use one of these adapters and an RCA cable of your choice:
http://www.fullcompass.com/product/297984.html
If you're having ground issues and you want to life the ground you can use a Direct Box with RCA inputs, such as this:
http://www.fullcompass.com/product/265769.html
Fan Mod:
http://www.hometheatershack.com/foru...er-ep2500.html
XanderMoser is offline
post #5 of 123 Old 08-29-2008, 10:35 AM - Thread Starter
How do I connect the eQ.2 in the middle?
I'm guessing RCA - RCA, then from eQ.2 RCA to XLR to the EP2500?(is an xlr the same as a TS adapter?)
post #6 of 123 Old 08-29-2008, 10:50 AM
whoaru99's Avatar
Liked: 69
XLR isn't the same as TS/TRS adapter.
XLR is the bigger round one with three pins, TS/TRS are the 1/4" diameter connections that resemble headphone plugs.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #7 of 123 Old 08-29-2008, 10:53 AM - Thread Starter
Being that the EP2500 has both types of inputs, Icould use either, correct?(no difference?)
Thanks so much for walking me through this guys!!!
post #8 of 123 Old 08-29-2008, 10:57 AM
NEO Dan's Avatar
RCA to XLR is the best way to go vs a RCA to 1/4" TS adapter
Best solution=
Dan
NEO Dan is offline
post #9 of 123 Old 08-29-2008, 11:05 AM
NEO Dan's Avatar
The important part is that the S is not conected to -siginal, USE A TRS connector if you go 1/4"
YOU NEED #18 IF YOU GO 1/4"
Dan
NEO Dan is offline
post #10 of 123 Old 08-29-2008, 11:07 AM
Jerm357's Avatar
Best solution=
Why would RCA to XLR be any better then RCA to 1/4" TS?
Jerm357 is offline
post #11 of 123 Old 08-29-2008, 11:16 AM
NEO Dan's Avatar
Ground loop hum
Dan
NEO Dan is offline
post #12 of 123 Old 08-29-2008, 11:22 AM
NEO Dan's Avatar
compaired to RCA to TS the RCA to XLR or TRS are much less likely to introduce a ground loop hum into the system.
Dan
NEO Dan is offline
post #13 of 123 Old 08-29-2008, 11:45 AM - Thread Starter
I just realized that I actually have an RCA to TS( i think-has a headphone end) from my computer to my AVR...I get horrible noise on that line, just aweful.
That was going to be my next project, to try to solve that.
So I will be getting two rca cables and a single XLR adapter...plus 35' of 12 guage speaker wire and some solder.
Thanks so much guys!!! Invaluable!
post #14 of 123 Old 08-29-2008, 02:27 PM
NEO Dan's Avatar
that awfull noise is why I was making all the fuss, LOL
TRS and XLR are your friends
Dan
NEO Dan is offline
post #15 of 123 Old 08-29-2008, 02:29 PM
NEO Dan's Avatar
Best low cost solution for your PC to AVR issue, go optical
http://www.turtlebeach.com/products/micro/home.aspx
Dan
NEO Dan is offline
post #16 of 123 Old 08-29-2008, 03:46 PM
mikeonyx's Avatar
Dan is right,
I currently have a RCA to 1/4" and I hear this ground hum. I isolated the source of the hum to the unbalanced signal. I am waiting for monoprice.com to release the RCA to XLR cable. The date of its release is in a few days -> 8/31.
If the ground hum continues, I will get this device to balance the signal and the upside is boosting the line to prosound level:
http://www.rackmount-devices.com/002-8485.html
mikeonyx is offline
post #17 of 123 Old 08-29-2008, 04:57 PM
catapult's Avatar
You still need to know the specifics of the cable. Whether it's XLR or TRS, you want two wires surrounded by a shield that's only connected at one end like Dan's pics show. If they build it with a simple coax wire, one wire and a shield, and connect (-) to the shield at the TRS or XLR connector, you will have all the same ground loop problems as an RCA-TS cable. Edit: even if they use two wires plus a shield, it fails if they connect the shield at the RCA end. Seems like you almost have to build it yourself to make sure it's right. Cut a TRS cable in half and solder RCAs on the ends like Dan's pic. If you buy one, make sure you can return it and check it out with an ohmmeter.
Dennis H
catapult is offline
post #18 of 123 Old 08-29-2008, 05:29 PM - Thread Starter
And what if those pictures are foreign to me and I don't know where to get one that is reliable from the factory....what would you advise?
post #19 of 123 Old 08-29-2008, 05:37 PM
NEO Dan's Avatar
order the parts from parts express & DIY for the win
or paypal me and i'll build it up
Dan
NEO Dan is offline
post #20 of 123 Old 08-29-2008, 06:23 PM - Thread Starter
Dan....PM sent.
post #21 of 123 Old 08-29-2008, 08:24 PM
penngray's Avatar
Liked: 47
Make 10 more
penngray is offline
post #22 of 123 Old 08-29-2008, 10:40 PM
Erich H's Avatar
Quoted: 1471 Post(s)
Liked: 1882
And a few more if I'm gonna need them too!
_______________________
The SEOS Waveguide Project
Erich H is offline
post #23 of 123 Old 08-29-2008, 11:27 PM
kingpin111's Avatar
Quoted: 290 Post(s)
Liked: 283
lol. Poor Dan. You guys better give him a good tip.
kingpin111 is offline
post #24 of 123 Old 08-30-2008, 01:18 AM
Don't use speaker wire! Use 2 conductor, shielded cable. Belden mic cable is a good choice. Speaker wire is not shielded, you will lose all shielding properties and won't get any noise protection. Especially with a 35' cable.
post #25 of 123 Old 08-30-2008, 03:47 AM
Rightbrained's Avatar
Here's my DIY XLR to RCA. I used Dayton Mic cable and Dayton connectors.
If at first you dont succeed , get a bigger hammer !
Rightbrained is offline
post #26 of 123 Old 08-30-2008, 07:07 AM - Thread Starter
So no speaker wire from amp to enclosure?
Beldin mic cable??
post #27 of 123 Old 08-30-2008, 09:09 AM
Yes , microphone cable is the correct cable to use for DIY 1/4 to RCA or XLR to RCA (like the ones I made). Mic cable has 2 insulated conductors and an outer shield which is used to connect chassis grounds on balanced connections. The shield is not used on the RCA (unbalanced) end of the cable that connects to your avr LFE output
You will use speaker wire from amp to sub . Xander was referring to the fact that you dont use speaker cable to make your interconnects.
post #28 of 123 Old 08-30-2008, 09:18 AM
Jerm357's Avatar
Yes, you will still need that. I think there talking about the input cable. You will still need speaker wire to go from the amp to the driver itself.
Jerm357 is offline
post #29 of 123 Old 08-30-2008, 10:19 AM
Looneybomber's Avatar
Liked: 27
As a temporary thing, I built my cables out of CAT5 just to get things hooked up one night. That's been more than a year ago now and noise has never been a problem. The cable however, doesn't fit the connectors very well (too small in dia.), so I will later build them correctly with the right cable.
YID DIY
Looneybomber is offline
post #30 of 123 Old 08-30-2008, 10:25 AM
allargon's Avatar
Quoted: 71 Post(s)
Liked: 49
re: the ground loop hum, several people have complained about that with the AudioSource AMP300 as well. I'm hoping to get one of those the next time they go on sale at the Fry's here in Austin. (They're on sale in Silicon Valley for a song this weekend!)
allargon is offline
