Cone excursion in sealed vs. ported cabinets? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-15-2008, 03:51 PM - Thread Starter
kenratboy's Avatar
Ignoring all sound quality issues (I know it is religious!), using the same driver, how is excursion affected? Specifically, a very small driver (3-4")?
I thought I heard in some cases, you would get more excursion in a sealed box (goes against the 'air spring' thing) compared to a properly-designed ported box.
Idea is - with a smaller driver and no high-pass filter, what is the best way to limit over excursion?
kenratboy is offline
post #2 of 3 Old 11-15-2008, 07:06 PM
zero the hero's Avatar
best way to limit excursion with no high-pass filter is to build a sealed box.
zero the hero is offline
post #3 of 3 Old 11-16-2008, 05:25 AM
goneten's Avatar
In a sealed box the maximum excursion is at resonance whereas a ported box has maximum damping at resonance.
Yes.
Turn the volume down.
goneten is offline
